29277 Discussions
Poperty for fortran project in vs2008
Viktor_T_
I installed vs2008 and visual fortran 11. Converted a project with c, c++, frortran from vs2005 where c is master. I can build the whole project but I can not open the property page on the fortran project. I get the following error: Class not registered. looking for object with clsid:{670f9cce-44da-44f6-97cf-b6dae7d4585}. An other problem is I can not open some of the files in the solution explorer. There I get the error: library not registered. Exception from hresult: 0x..... .
I uninstalled fortran und installed again. Did not help.
Any Id?
Steven_L_Intel1
Try this.
  • Unpack the attached ZIP file to a convenient folder.
  • Open a command prompt window (Start > Run > CMD)
  • Change directory (cd) to the folder containing RepairVS08Integration.exe
  • Type the following commands:
    • SET PATH=
    • SET LIB=
    • SET INCLUDE=
    • RepairVS08Integration
Now reopen Visual Studio and try again.
Viktor_T_
Sorry but how can I get the attached file? Thanks
Steven_L_Intel1
I suppose it would help if I had actually attached the file. Sorry. I edited the post to do so.
Viktor_T_
I got the following messages:
Visual Studio 2008 installed at C:Program FilesMicrosoft Visual Studio 9.0
Successfully unregistered VFHieEditor.dll
Successfully unregistered VFAVwin.dll
Successfully unregistered VFFortSvc.dll
Successfully unregistered VFProjConvert.dll
Successfully unregistered VFProj.dll
Successfully unregistered VFToolOpt.dll
Successfully registered VFToolOpt.dll
Error while registering VFProj.dll: Access is denied.
Press any key to exit program
What I did:
shut down system and rebooted
I am administrator
command window:
SET PATH=
runned utility
why access denyed?
Steven_L_Intel1
I have seen other cases where this happens. Some customers found that parts of their registry had been set to "no write access", by what, they did not know. I have also heard that some antivirus programs do things like this, so try disabling your antivirus temporarily and run the repair again.
Viktor_T_
Thank you. It was not the scaner it was the registry. The protections were completly wrong. I set them to some for me suitabele value but the system did not run well. I had to reinstall! I understand now the black belt!
