Please find below an issue (and reproducer) encountered by one of our development
team members.
Eric
_______________________________________________________
Encountered an ICE in ifort 17.0.1.132 Build 20161005 attempting to cross-compile AVX512 on a Xeon.
CPU: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
OS: Linux K-li2 2.6.32-642.13.1.el6.centos.plus.x86_64 #1 SMP Thu Jan 12 11:45:05 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Example code:
program main
implicit none
real(8) :: turb, baseterm, sw
turb = 1.0_8
sw = 1.0_8
baseterm = turb * (-1.0_8)*1.0_8/sw + 1.0_8/sw
end program
Other info:
No error on versions:
15.3.187
16.0.109
16.2.181
16.3.210
17.0.098
Log showing only certain flag combos trigger the ICE:
user@K-li2% ifort -std03 -xMIC-AVX512 -O2 -fpe0 -c -o turb_spalart_mod.o turb_spalart_mod.f90
catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for turb_spalart_mod.f90 (code 1)
user@K-li2% ifort -std03 -xMIC-AVX512 -O2 -fpe1 -c -o turb_spalart_mod.o turb_spalart_mod.f90
[no error]
user@K-li2% ifort -std03 -xMIC-AVX512 -O2 -fpe0 -fp-model strict -c -o turb_spalart_mod.o turb_spalart_mod.f90
[no error]
user@K-li2% ifort -std03 -xMIC-AVX512 -O2 -fpe0 -fp-model precise -fp-model except -c -o turb_spalart_mod.o turb_spalart_mod.f90
010101_14277
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
Avoided the error with the following tweak:
baseterm = 1.0_8/sw - turb*1.0_8/sw
Hi Eric,
I believe the error may be occurring during constant folding (constant evaluation) during compilation - that's why changing how the expression is evaluated works around. I'm not sure why -fpe0 triggers it. The good news is that this problem no longer occurs with the version 17.0.2 (2017 update 2) compiler that was posted to the Intel Registration Center last week. Please try that compiler on your larger application, and let us know if there are still any problems.
