Possible bug in Intel Fortran with GENERIC OPERATOR extension?
FortranFan
This is based on an ongoing discussion at the comp.lang.fortran forum (https://groups.google.com/forum/#!topic/comp.lang.fortran/aFNK3FXqTUA) on generic operator bindings to specific type-bound procedures and their extensions with extended derived type.  The simple code shown below is based on the postings in that thread as well as a companion thread at the gfortran gnu website.  This code appears alright with respect to the latest Fortran standard and it compiles and executes as expected using gfortran 4.9.  However, Intel Fortran compiler 15 raises an error which seems to be incorrect.
MODULE m
   IMPLICIT NONE
   PRIVATE
   TYPE, PUBLIC :: A_t
      PRIVATE
      INTEGER :: m_i = 0
   CONTAINS
      PRIVATE
      PROCEDURE, PASS(This) :: A_sum => sum_i
      GENERIC, PUBLIC :: OPERATOR(+) => A_sum
   END TYPE A_t
   TYPE, EXTENDS(A_t), PUBLIC ::  C_t
      PRIVATE
      REAL :: m_r = 1.0
   CONTAINS
      PROCEDURE, PASS(This) :: A_sum => sum_r
      PROCEDURE, PASS(This) :: C_sum => sum_s
      GENERIC, PUBLIC :: OPERATOR(+) => C_sum
   END TYPE C_t
   TYPE, PUBLIC :: S_t
      PRIVATE
      CHARACTER(LEN=6) :: m_s = "Hello!"
   END TYPE S_t
CONTAINS
   FUNCTION sum_i(This, Rhs) RESULT(RetVal)
      !.. Argument list
      CLASS(A_t), INTENT(IN) :: This
      INTEGER, INTENT(IN)    :: Rhs
      !.. Function result
      INTEGER :: RetVal
      RetVal = This%m_i + Rhs
      WRITE(*,*) 'In sum_i'
      RETURN
   END FUNCTION sum_i
   FUNCTION sum_r(This, Rhs) RESULT(RetVal)
      !.. Argument list
      CLASS(C_t), INTENT(IN) :: This
      !.. Function result
      INTEGER :: RetVal
      RetVal = INT(This%m_r, KIND=KIND(RetVal)) + Rhs
      WRITE(*,*) 'In sum_r'
      RETURN
   END FUNCTION sum_r
   FUNCTION sum_s(This, Rhs) RESULT(RetVal)
      !.. Argument list
      CLASS(S_t), INTENT(IN) :: Rhs
      !.. Function result
      CHARACTER(LEN=6) :: RetVal
      IF (This%m_i == 0) THEN
         RetVal = Rhs%m_s
      END IF
      WRITE(*,*) 'In sum_s'
      RETURN
   END FUNCTION sum_s
END MODULE m
PROGRAM p
   USE m, ONLY : A_t, C_t, S_t
   IMPLICIT NONE
   !.. Local variables
   TYPE(A_t) :: A
   TYPE(C_t) :: C
   TYPE(S_t) :: S
   INTEGER :: I
   CHARACTER(LEN=6) :: G
   PRINT *, " Test #59: Generic Operator Extension "
   I = A + 1
   PRINT *, " I = ", I
   I = C + 1
   PRINT *, " I = ", I
   G = C + S
   PRINT *, " G = ", G
   STOP
END PROGRAM p
The compiler error is as follows:
1>Compiling with Intel(R) Visual Fortran Compiler XE 15.0.0.108 [Intel(R) 64]...
1>TestFor.f90
1>TestFor.f90(21): error #6355: This binary operation is invalid for this data type.
1>TestFor.f90(21): error #6549: An arithmetic or LOGICAL type is required in this context.
1>TestFor.f90(21): warning #6191: Fortran 2008 requires an arithmetic data type in this context.
1>TestFor.f90(21): error #6303: The assignment operation or the binary expression operation is invalid for the data types of the two operands.
1>compilation aborted for TestFor.f90 (code 1)
Note there is also another issue with Intel Fortran compiler giving an incorrect result if line 45 in module m i.e., if the generic operator + binding extension to another specific type-bound procedure is removed.  This is part of the question at the comp.lang.fortran thread.
FortranFan
FWIW, gfortran 4.9 gives the following result for the code shown above.
 In sum_i
  I =            1
 In sum_r
  I =            2
 In sum_s
  G = Hello!
Process returned 0 (0x0)   execution time : 0.016 s
Press any key to continue.
Steven_L_Intel1
Thanks, we'll take a look.
TimP
My results for gfortran 5.0 and ifort on Windows were as quoted for linux.
Steven_L_Intel1
I've gone through the comp.lang.fortran thread and the gcc thread it references. The program here differs substantially from what I see discussed in those threads, though there's a lot of back-and-forth and I may have missed something.
For the program presented here, I believe it should not compile, though the reason for that is different from what ifort says, in my opinion. Type C_t overrides the procedure A_sum, yet the non-passed dummy argument has a different type in the original and overriding procedures. This is not legal:
"The overriding and overridden type-bound procedures shall satisfy the following conditions:
- Dummy arguments that correspond by position shall have the same names and characteristics, except for the type of the passed-object dummy arguments"
This was brought up in the c.l.f thread. ifort should be disallowing that override and I will let the developers know.
But if I modify the program to avoid this issue, others arise, so I am still working on this.
FortranFan
Steve,
Yes, the issue I'm presenting here is different but the code and concept were "inspired" by the threads at comp.lang.fortran and gcc.
in my opinion. Type C_t overrides the procedure A_sum, yet the non-passed dummy argument has a different type in the original and overriding procedures. This is not legal.
I'm not sure I understand: the overriding procedure for A_sum in type C_t is sum_r which has the same type of integer for the second (non-passed) dummy argument.  So why is that not legal?
Perhaps you're thinking of the additional specific type-bound procedure of sum_s.  But note this procedure is supposed to "extend" the generic operator of + with the binding at line 45.  And from what I can understand, this is legal - is it not?
Steven_L_Intel1
Oops - I missed that the types are the same - too many variations to look at.
Extending the generic this way is correct. Let me play with this some more....
Steven_L_Intel1
Ok, this is the same as the issue reported in https://software.intel.com/en-us/forums/topic/534286 The bug tracking issue number is DPD200362489
Steven_L_Intel1
Fixed in 16.0.
