29583 Discussions
Possible bug in ifort: using polymorphic types
Luckner__Paul
I get different results depending if I comment specific lines out or not (even as those are not accessed at runtime). The bug does not appear using gfortran.
program main
  implicit none
  type :: parent
    integer              :: i1
    integer, allocatable :: i2
  end type
  type, extends(parent) :: child
    integer              :: i3
    integer, allocatable :: i4
  end type
  type :: parent_alc
    class(parent), allocatable :: p
  end type
  type(parent_alc) :: p_alc
  if (.false.) then
    block
      ! type(child) :: e            ! comment this line in/out for different results
    end block
  else
    block
      type(child)      :: c
      c%i1 = 1
      c%i2 = 1
      c%i3 = 1
      c%i4 = 1
      ! method 1: broken in ifort
      ! p_alc%p = c
      ! method 2: broken in ifort
      ! allocate (p_alc%p, source=c)
      ! workaround
      allocate (child :: p_alc%p)
      select type (x => p_alc%p)
        type is (child)
          x%i1 = c%i1
          x%i2 = c%i2
          x%i3 = c%i3
          x%i4 = c%i4
      end select
      c%i1 = 0
      c%i2 = 0
      c%i3 = 0
      c%i4 = 0
    end block
  end if
    type is (child)
      print *, 'p_alc%p%i1..4', x%i1, x%i2, x%i3, x%i4
  end select
end program
Running the program using method 1,2 and commenting in/out the highlighted line 23 yields different results with ifort and the same in gfortran.
Line commented out
$ ifort main.f90 && ./a.out
p_alc%p%i1..4           1           1           1           1
$ gfortran main.f90 && ./a.out
Line not commented out
p_alc%p%i1..4           1           0           1           0
Program versions
$ ifort --version
ifort (IFORT) 19.0.1.144 20181018
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
$ gfortran --version
GNU Fortran (Arch Linux 9.3.0-1) 9.3.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
The "workaround" code actually works under ifort/gfortran with and without line 23.
FortranFan
An option you may want to consider if possible is to update your compiler version.  Version 19.1 appears not to face the issue:
C:\Temp>type p.f90
program main
   implicit none
   type :: parent
      integer              :: i1
   end type
      integer              :: i3
   end type
   type :: parent_alc
   end type
   if (.false.) then
      block
      end block
   else
      block
         type(child)      :: c
         c%i1 = 1
         c%i2 = 1
         c%i3 = 1
         c%i4 = 1
         p_alc%p = c
      end block
   end if
      type is (child)
   end select
end program
C:\Temp>ifort /standard-semantics /warn:all /stand:f18 p.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
p.f90(23): remark #7712: This variable has not been used.
Microsoft (R) Incremental Linker Version 14.24.28316.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:p.exe
-subsystem:console
p.obj
C:\Temp>p.exe
C:\Temp>
C:\Temp>type p.f90
program main
   implicit none
   type :: parent
      integer              :: i1
   end type
      integer              :: i3
   end type
   type :: parent_alc
   end type
   if (.false.) then
      block
      end block
   else
      block
         type(child)      :: c
         c%i1 = 1
         c%i2 = 1
         c%i3 = 1
         c%i4 = 1
      end block
   end if
      type is (child)
   end select
end program
-out:p.exe
-subsystem:console
p.obj
C:\Temp>p.exe
C:\Temp>
Luckner__Paul
Thanks for the fast reply!
I will try it out with the newer version. Hope it works and not some internal thing caused by the underlying OS (linux/windows).
IanH
The code in #2 is missing the trailing assignment statements necessary to see the bug - 19.1 is still problematic.
I have encountered issues previously with over-enthusiastic deallocation of block local variables (or components of block local variables) with the current compiler.  I suspect that is going on here - move the block local variables up to the enclosing scope and the symptoms disappear.
FortranFan
Bummer!  Support request at Intel OSC appears to be in order: https://supporttickets.intel.com/servicecenter?lang=en-US ;
