29650 Discussions
Possible missing Macro definition with Visual Studio 2017
Ibrahim_K_
I have created a new project with a C++ main and a Fortran static library subroutine. It all seems to be OK. However linking fails as the Fortran Sttaic library definition is missing in the Link>Input field. It seems like Intel Fortran macro which creates the Library Project seems to add a Macro called "%(Additional Dependencies)" which seems to be never defined as it can be seen from the following picture:
I can see that Fortran compiler compiles and creates the library. I am attaching the solution ZIP file. I can always enter the Libray location manually, but I want to find a better solution. Any help would be appreciated.
I. Konuk
Steve_Lionel
The problem is that, as of VS2015, C++ projects no longer include non-C++ dependent projects in link dependencies. You have to manually add the Fortran library to the link properties or as a source file in the C++ project.
