Potential loop unrolling bug in ComposerXE 2013
Marianne_S_
I have found a potential bug with the loop unrolling of a triangular loop.  The example is attached.
[marianne@MarianneFedora15 ~]$ ifort -v
ifort version 13.0.1
[marianne@MarianneFedora15 ~]$ ifort loopUnrolltest.f90
[marianne@MarianneFedora15 ~]$ ./a.out
   1000000.       1000000.      3.3835000E+07  0.0000000E+00  0.0000000E+00
  0.0000000E+00
[marianne@MarianneFedora15 ~]$ ifort -unroll0 loopUnrolltest.f90
  3.3835000E+07  3.3835000E+07  3.3835000E+07  3.3835000E+07  3.3835000E+07
  3.3835000E+07
Ron_Green
Bug report entered.  We will inform you when a fix gets into the compiler.
Thank you for such a good concise reproducer!  This really helps us.
ron
Marianne_S_
I am just glad I was able to actually reproduce it separately from our main code.  That does not usually happen!
Thanks for submitting the bug report.
Marianne_S_
Is it possible to get a ticket number or something for this issue?  My management has asked me for one.  I had issues logging into the premier support to submit this myself which is why I posted it here in the first place.
Kevin_D_Intel
The internal bug report id Ron filed for the issue is DPD200240713
Ron_Green
this bug was fixed in Composer XE 2013 Update 3, aka 13.1.1.163 build 20130313.
thank you for reporting this bug.
ron
