I have found a potential bug with the loop unrolling of a triangular loop. The example is attached.
[marianne@MarianneFedora15 ~]$ ifort -v
ifort version 13.0.1
[marianne@MarianneFedora15 ~]$ ifort loopUnrolltest.f90
[marianne@MarianneFedora15 ~]$ ./a.out
1000000. 1000000. 3.3835000E+07 0.0000000E+00 0.0000000E+00
0.0000000E+00
[marianne@MarianneFedora15 ~]$ ifort -unroll0 loopUnrolltest.f90
3.3835000E+07 3.3835000E+07 3.3835000E+07 3.3835000E+07 3.3835000E+07
3.3835000E+07
Bug report entered. We will inform you when a fix gets into the compiler.
Thank you for such a good concise reproducer! This really helps us.
ron
I am just glad I was able to actually reproduce it separately from our main code. That does not usually happen!
Thanks for submitting the bug report.
Is it possible to get a ticket number or something for this issue? My management has asked me for one. I had issues logging into the premier support to submit this myself which is why I posted it here in the first place.
The internal bug report id Ron filed for the issue is DPD200240713
this bug was fixed in Composer XE 2013 Update 3, aka 13.1.1.163 build 20130313.
thank you for reporting this bug.
ron
