29386 Discussions
Pre-compilation to remove all the debug tests and prints
bucaioni__thomas
Is there a pre-compilation phase to remove all the debug tests, for example:
# PRE_COMPIL_FLAG_BEGIN
print *, "Check of variable V: V = ", V
if (V.le.0) then
print *, "Bug"
stop
end if
# PRE_COMPIL_FLAG_END
and when compiling for optimized execution, having all these lines removed?
Arjen_Markus
You can use the preprocessor step for this, this is typically done via:
#ifdef PRE_COMPIL_FLAG
your debug code
#endif
 For this to work you need to specify the compile option /fpp (in VS it is the first option under "Preprocessor")
Arjen_Markus
your debug code
#endif
jimdempseyatthecove
Or use:
!dir$ if defined(PRE_COMPIL_FLAG)
your debug code
!dir$ endif
Then you do not need to use fpp.
Jim Dempsey
bucaioni__thomas
