This is really frustrating. I am trying to write a line to the DOS window which is longer than 80 columns long. No matter what I do it wraps around at 80 columns. I change the layout properties of the DOS command window so that it is 132 columns. The window becomes wider, but running the Fortran program, the output line still wraps around at 80 columns on the screen. What is the problem? and how to solve it? I really appreciate it.
Very Frustrated
You are absolutely right. I was using
write(6,*) 'longer than 80 columns text'
format which on screen wraps at 80. But by using
write(6,'(1x,A)') '...' I got around the problem. But do you know why list-directed format is limited to 80? Is there a way to change the default for it? Thanks. I really appreciate your response.
Vahrazj
For printing more columns in DOS window you should adjust your DOS box. Windows 2000/XP allow set up as many columns/rows in the DOS window as you want. But you can have some problems in the fullscreen DOS session.
If you want to print reports on the printer which have more than 80 columns you should use escape sequences which allow print in condensed mode.
Also you can use special utilitie http://www.dosprn.comwhich can print DOS reports with specified font size.
I can't seem to get that to work. I'm using IVF v9.1.3250.2003. Here is my test program:
program T_ListDirRecL
implicit none
integer :: i,j
OPEN ( 6, FILE='CON', STATUS='UNKNOWN', RECL=100 )
print '(100a)', ' ', ( ' ',char(48+i) , i=1,9 )
print '(100a)', ( ( char(j+48), j=0,9 ), i=0,9 )
print *, ' '
print *, ' ', ( ' ',char(48+i) , i=1,9 )
print *, ( ( char(j+48), j=0,9 ), i=0,9 )
stop
end program T_ListDirRecL
The formatted prints work just fine, but the list directed ones wrap at column 79 (that's where that last character occurs). If I set RECL=10, I get the exact same output. It appears to me the RECL parameter is ignored for list-directed output. Is there some switch I need to set to tell the compiler to honor my RECL setting? The use or non-use of /assume:byterecl seems to have no effect either.
I had been cursing this lack of control all week when a coworker walked in and asked if the 80-column limit could be eliminated, so I decided I'd try here.
Marshall
write(6,*) ( ( char(j+48), j=0,9 ), i=0,9 )
It gives the exact same output as a PRINT *. Try it!
Marshall
Thanks for trying it. Should I open a new issue? This is really annoying.
Marshall
Here's how it works for me: in Win API speak,
!use whichever of these modsare appropriate
use dfwin
use user32
use dfwinty
use kernel32
type(T_COORD) ScrSize
type(T_CONSOLE_SCREEN_BUFFER_INFO) ScrBuff
AllocConsole
GetConsoleScreenBufferInfo(GetStdHandle(STD_OUTPUT_HANDLE), ScrBuff)
ScrSize.X = 2*ScrBuff.dwMaximumWindowSize.X !Default is 80
ScrSize.Y = 100*ScrBuff.dwMaximumWindowSize.Y !Default is 25
Maximize the console window when it appears. It should be big enough.
PS
Oh, I forgot:
SetConsoleScreenBufferSize(GetStdHandle(STD_OUTPUT_HANDLE,ScrSize)
A workaround is to use some other unit such as 8.
