29487 Discussions
Problem during compilation of DFLUX abaqus subroutine
ALOK_05
hello everyone,
I am trying to compile Fortran code in the Abaqus DLUX subroutine. I am very not in this field. I tried to compile Fortran code but it is getting failed " compilation aborted" statement.
DFLUX subroutine for Abaqus is as follows :
SUBROUTINE DFLUX(FLUX,SOL,KSTEP,KINC,TIME,NOEL,NPT,COORDS,JLTYP,TEMP,PRESS,SNAME)
C
      INCLUDE 'ABA_PARAM.INC'
C
      DIMENSION FLUX(2), TIME(2), COORDS(3),
      CHARACTER*80 SNAME
      X=COORDS(1)
  Y=COORDS(2)
  Z=COORDS(3)
  Dist = 0.0
  Y_center = 0.0 - ((0.1/100.0)*(TIME(2)))
  X_center = 0.0
  YT=Y_center - Y
  XT=X_center - X
  Dist = SQRT((YT*YT)+(XT*XT))
  if (Dist .le. 0.01) then
     FLUX(1) = 50000.0
  else
     FLUX(1) = 0.0
  endif
      RETURN
      END
however, when I ran it in Abaqus, it aborted with the following error:
D:\abaqus\Gausian\2file>abaqus job=Moving_Hf user=trail12 interactive
Analysis initiated from SIMULIA established products
Abaqus JOB Moving_Hf
Abaqus 2021
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 5 tokens from Flexnet server ###.##.###.###.
<** out of ** licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
6/29/2023 3:24:47 PM
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
trail12.f(5): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: <IDENTIFIER>
compilation aborted for trail12.f (code 1)
Abaqus Error: Problem during compilation - trail12.f
Abaqus/Analysis exited with errors
I have also attached the Fortran code file.
 Anyone could help me and thanks in advance.
jimdempseyatthecove
To expand on mecej4's post...
Suggest you compile as free-form.
one of:
a) !DIR$ FIXEDFORMLINESIZE:132
    to top of program
b) rename the source file as trail12.f90 (indicates source is free form)
c) add option /free or /nofixed
d) add option /extend-source:132
Jim Dempsey
mecej4
The first line of your program is longer than 72 characters, which is not allowed in standard fixed form Fortran source.
There is an unexpected comma character at the end of the DIMENSION... line in your program.
jimdempseyatthecove
one of:
    to top of program
Jim Dempsey
