ifx_ice.f90(11): error #5623: **Internal compiler error: internal abort** Please report this error along with the circumstances in w
hich it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
chars = transfer(any_scalar, chars)
compilation aborted for ifx_ice.f90 (code 3)
! ifx (IFX) 2023.1.0 20230320
module m_any_scalar
use, intrinsic :: iso_fortran_env, only: csz => character_storage_size
implicit none
contains
function any_scalar_to_bytes(any_scalar) result(chars)
class(*), intent(in) :: any_scalar
character(len=1), allocatable :: chars(:)
if (allocated(chars)) deallocate (chars)
allocate (chars(storage_size(any_scalar)/csz))
end function any_scalar_to_bytes
end module m_any_scalar
program main
use M_any_scalar, only : any_scalar_to_bytes
write(*,'(*(z2.2))') any_scalar_to_bytes('1234567890')
write(*,'(*(z2.2))') any_scalar_to_bytes(100)
write(*,'(*(z2.2))') any_scalar_to_bytes(2.0+2.0)
end program main
Congratulations! This ICE is fixed in a compiler that should be available at the end of the summer (in the northern hemisphere).
I don't know if this the same issue as the other thread. It's hard to know what goes on under the covers. But that one also is fixed in a compiler available later this year.
Thank you for reporting this!
I just confirmed that the ICE with ifx is gone with the compiler that will be available in the next few weeks.
Is this the output you expect?
Could not find your output. I expect the program to produce the following three lines
31323334353637383930
64000000
00008040
My bad on not posting the output. I get the same thing.
64000000
00008040
