29277 Discussions
call to transfer with class(*) causes ICE in ifx, but works with ifort
ur
New Contributor II
ifx_ice.f90(11): error #5623: **Internal compiler error: internal abort** Please report this error along with the circumstances in w
hich it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
chars = transfer(any_scalar, chars)
compilation aborted for ifx_ice.f90 (code 3)
! ifx (IFX) 2023.1.0 20230320
module m_any_scalar
   use, intrinsic :: iso_fortran_env, only: csz => character_storage_size
   implicit none
contains
   function any_scalar_to_bytes(any_scalar) result(chars)
      class(*), intent(in)          :: any_scalar
      character(len=1), allocatable :: chars(:)
      if (allocated(chars)) deallocate (chars)
      allocate (chars(storage_size(any_scalar)/csz))
   end function any_scalar_to_bytes
end module m_any_scalar
program main
use M_any_scalar, only : any_scalar_to_bytes
   write(*,'(*(z2.2))') any_scalar_to_bytes('1234567890')
   write(*,'(*(z2.2))') any_scalar_to_bytes(100)
   write(*,'(*(z2.2))') any_scalar_to_bytes(2.0+2.0)
end program main
Barbara_P_Intel
Congratulations! This ICE is fixed in a compiler that should be available at the end of the summer (in the northern hemisphere).
I don't know if this the same issue as the other thread. It's hard to know what goes on under the covers. But that one also is fixed in a compiler available later this year.
Thank you for reporting this!
martinmath
Looks like the same bug as reported in ICE-in-ifx-with-transfer-for-a-class-variable
Barbara_P_Intel
Barbara_P_Intel
I just confirmed that the ICE with ifx is gone with the compiler that will be available in the next few weeks.
Is this the output you expect?
ur
New Contributor II
Could not find your output. I expect the program to produce the following three lines
31323334353637383930
64000000
00008040
Barbara_P_Intel
My bad on not posting the output. I get the same thing.
64000000
00008040
