Annonces
Problem importing Fortran routine from a dll
Kipling__Michael
Débutant
1 293 Visites
I have a Fortran console application which is trying to import a routine from a Fortran dll.  I'm getting the following error message when linking.
error LNK2019: unresolved external symbol __imp__USELOG referenced in function _MAIN__
The interface for the routine is:
INTERFACE
   SUBROUTINE USELOG(logname, progname, version)
      !DEC$ ATTRIBUTES, ALIAS:'USELOG' :: USELOG
      !DEC$ ATTRIBUTES DLLIMPORT :: USELOG
      CHARACTER(LEN=26) :: logname
      CHARACTER(LEN=26) :: progname
      CHARACTER(LEN= 5) :: version
      !DEC$ ATTRIBUTES REFERENCE :: logname, progname, version
   END SUBROUTINE USELOG
END INTERFACE
The routine USELOG uses the following code for exporting:
   !DEC$ ATTRIBUTES DLLEXPORT :: USELOG
   !DEC$ ATTRIBUTES ALIAS:'USELOG' :: USELOG
   !DEC$ ATTRIBUTES REFERENCE :: logname_, progname_, version_
When I view the dll using dependency walker the routine is shown as USELOG without any decoration.
Could someone please tell me how to import this correctly.
Regards, Mike
0 Compliments
11 Réponses
Steven_L_Intel1
Employé
1 293 Visites
You need to link against the .lib generated when the DLL was built. If you tried linking to the DLL directly, that was ignored.
0 Compliments
Kipling__Michael
Débutant
1 293 Visites
I did link against the import lib.  I have it listed in the Linker/Advanced/Import Lib.
I also added the import lib to the project.
Mike
0 Compliments
Steven_L_Intel1
Employé
1 293 Visites
Ah - I've seen that error before. That's not the right place to add that. You want it under Additional Dependencies. What you did was tell the linker to name the import library it creates, if it created one, which it won't for an executable project. Treat the import library the same as a static library.
0 Compliments
Kipling__Michael
Débutant
1 293 Visites
You are correct Steve.  I think I moved the import lib address from the Additional Dependencies in an attempt to fix the original problem which is an unresolved external.
I am trying to use the routine USELOG from the dll.  If I use an interface block in the calling program, I get this error:
error LNK2019: unresolved external symbol __imp__USELOG referenced in function _MAIN__ Besthb.obj
If I do not use an interface block, I get the following error:
error LNK2019: unresolved external symbol _USELOG referenced in function _MAIN__
Both errors say that the linker is looking for the routine USELOG with a prefix to the routine name.
Dependency Walker does not show any prefix when looking at the dll.
Mike
0 Compliments
Kipling__Michael
Débutant
1 293 Visites
I decided to try a different approach.  I created a static library to replace the dll.  I added that as the additional dependency instead of the dll import library.  I eliminated the Interface block.  However, I still get the error:
The USELOG routine does show up as _USELOG in a Dumpbin listing of the static library.
Mike
0 Compliments
Kipling__Michael
Débutant
1 293 Visites
I solved the underlying problem.
In the UseLog routine being exported from the dll, the DECORATE command was missing.
The codes should have read:
!DEC$ ATTRIBUTES DECORATE, ALIAS:'USELOG' :: USELOG
Question: Is it possible to tell the calling routine not to expect decoration?
Regards, Mike
0 Compliments
Steven_L_Intel1
Employé
1 293 Visites
You could remove the ALIAS,DECORATE directive entirely in both the called routine and the caller. since all you're doing is restating the default.
When you use DLLIMPORT, the __imp__prefix is added. This is resolved by the import library and tells the linker to optimize the call (removes a few extra instructions. You don't see the prefix when examining the library or DLL. DLLIMPORT is optional when calling procedures, but is required if you are referencing variables or COMMON blocks in DLLs.
I will also comment that a nice way to handle this sort of thing is to put your DLL routine in a module, with DLLEXPORT. Then when the called program USEs the module, it will automatically get the interface AND do a DLLIMPORT. DO make sure that the executable links to the DLL run-time libraries.
0 Compliments
Kipling__Michael
Débutant
1 293 Visites
I use modules in VB, but haven't used them in Fortran.
Are you suggesting placing the entire routine in a module like the sample code below, or only a interface block?
MODULE MOD_TEST
   SUBROUTINE UseLog(logname, progname, version)
   IMPLICIT NONE
   INTERFACE
     SUBROUTINE USE_LOG(logname, progname, version);
       !DEC$ ATTRIBUTES DLLIMPORT :: USE_LOG
       !DEC$ ATTRIBUTES DECORATE, ALIAS:'use_log' :: USE_LOG
       CHARACTER(LEN=5)  :: version
     END SUBROUTINE USE_LOG
   END INTERFACE
    ! Type call list variables
   CHARACTER(LEN=26), INTENT(IN) :: logname
   CHARACTER(LEN=26), INTENT(IN) :: progname
   CHARACTER(LEN=5),  INTENT(IN) :: version
   CALL Use_Log(logname, progname, version)
   RETURN
   END SUBROUTINE UseLog
END MODULE_TEST
Mike
0 Compliments
Steven_L_Intel1
Employé
1 293 Visites
You would take out the INTERFACE - a routine in a module provides its own interface. See Doctor Fortran Gets Explicit - Again! for more information. Then add a USE MOD_TEST to the main program where you want the subroutine to be visible. You'll need to make the .mod file created when the module was compiled visible to the "Includes" path when building the executable. If you simply make the DLL project a dependent of the executable project, everything will be done automatically.
0 Compliments
Kipling__Michael
Débutant
1 293 Visites
In the sample code, the INTERFACE is actually for the routine USE_LOG  which is a C routine in another dll.  The Fortran routine USELOG is calling USE_LOG.
Mike
0 Compliments
Steven_L_Intel1
Employé
1 293 Visites
Ah, I see. Yes, you need an interface for the C routine.
0 Compliments
Répondre
