29275 Discussions
Problem in ifort 19.1.2.254 with arr = arr(v)
ccorrado
It seems that the last versions of intel compilers have problem with this type of operation
arr(:) = arr(v)
where arr is an allocatable array of derived type with a member that is an allocatable array, v is an array of integer.
I have used ifort Ubuntu 20.04.1 LTS with ifort 19.1.2.254 and 19.1.3.304.
You can reproduce the problem compiling the file test.f90.
The result with ifort 19.1.2.254 or 19.1.3.304
XTEST before = 1 2 3 4 5 6 7 8 9 10
XTEST after = 1 2 3 4 5 6 7 8 9 10
is wrong. The correct result is:
XTEST after = 10 9 8 7 6 5 4 3 2 1
that could be obtained compiling with gfortran or with old version of ifort, e.g. 19.0.0.117, 19.0.4.243.
Ron_Green
Yes, this is an interesting bug for sure.
I will write up a bug report.
Ron_Green
Bug ID is CMPLRIL0-33408
Barbara_P_Intel
This bug is fixed now. Please try the current Fortran compiler release, 2021.4.0, at let me know how it works for you. It's part of oneAPI HPC Toolkit 2021.4.
