Problem with TRIM and getcwd
Felix_F_1
初学者
1,984 次查看
Hi everyone,
The TRIM function in combination with getcwd doesn't do anything for me. Why is that so? Any ideas?
CHARACTER(len=255)                           :: cwd
Character(:),allocatable                            :: trim_cwd
CALL getcwd(cwd)
trim_cwd = TRIM(cwd) ! still holds all the trailing spaces
Felix
0 项奖励
9 回复数
Steven_L_Intel1
1,984 次查看
Your program doesn't demonstrate anything - how do you know TRIM doesn't work? When I construct an example using your code, it does work for me.
    program U506416
CALL getcwd(cwd)
print *, len(trim_cwd), trim_cwd
    end program U506416
          19 C:\Projects\U506416
0 项奖励
Felix_F_1
初学者
1,984 次查看
I am aware that it should work, since I make use of TRIM frequently in my code.
However in this particular situation a path with character length of 62 to the working directory is not trimmed. The length remains 255. Also len_trim() returns 255 as length.
So there is no known issue I have to consider here?
Is there any workaround?
Felix
0 项奖励
DavidWhite
重要分销商 II
1,984 次查看
What is Len_Trim(cwd)?
David
0 项奖励
DavidWhite
重要分销商 II
1,984 次查看
Like Steve, I find that your program works as expected with exactly just the directory name in trim_cwd.
I suspect that the code you have given us here is not the exact code in your program, and that something else is happening to cwd before you do the assignment to trim_cwd.  Note that cwd will in fact still have the full string, including all trailing blanks.
David
0 项奖励
Xj_Kong
新手
1,984 次查看
Actually, I agree that this happened before for me as well. Unfortunately, I forgot how to change the project setting to correct that.
Anyway, I avoid to use trim() and len_trim() by ctrim() and clen().
PURE INTEGER FUNCTION Clen(s,endl)    ! get len of string (C or tab\blank terminated)
CHARACTER(*),INTENT(IN)::s
character,INTENT(IN),optional::endl
character::endch
integer::nl,ne
endch=char(0); nl=len(s);
if(present(endl))then; endch=endl; do while(s(nl:nl)==endch); nl=nl-1; if(nl==0)exit; enddo; endif
Clen=scan(s(:nl),endch,.false.)-1
IF(Clen==-1)then
    Clen=LEN_TRIM(s)  ! not C string, Ctrim==TRIM
else
    Clen=LEN_TRIM(s(:Clen))  ! if C string, Ctrim==remove blank before NULL
end if
END FUNCTION Clen
pure FUNCTION Ctrim(s1)  RESULT(s2)   ! trim a string (C or blank terminated)
CHARACTER(*),INTENT(IN)::s1 !+min(1,scan(s1,char(0)))
character(clen(s1//"")+min(1,scan(s1,char(0))))::s2 ! //"" to convert pointer string to character string and set output length to 1st null -1 or last char
s2=s1; if(scan(s1,char(0))/=0)s2=s2(:clen(s2))//""C
END FUNCTION Ctrim
0 项奖励
Steven_L_Intel1
1,984 次查看
There is no project setting relevant to this.
0 项奖励
jimdempseyatthecove
名誉分销商 III
1,984 次查看
Is it possible that your original string was NULL terminated after a series of trailing blanks?
In this case, as far as Fortran is concerned, the NULL character is a significant non-blank character.
Jim Dempsey
0 项奖励
rase
新分销商 I
1,984 次查看
I had a similar problem when I was a newbee at mixed programming. I was not aware that the terminating Null character in character strings transfered to C programs by a calling Fortran program is not the same as a blank character. I would check the string for nonprintable characters, including the Null character. Nonprintable characters could have been inserted for other reasons than mixed programming.
0 项奖励
Steven_L_Intel1
1,984 次查看
I see in another of Felix's posts that he is apparently using version 11.0. In that version, one did need to use /assume:realloc_lhs for allocatable, deferred-length character variables. That requirement was removed in version 11.1 in 2009.
0 项奖励
回复
