29285 Discussions
Problem with Xcode 5.0.1 and XE Composer SP1
Claude_Perron
I just purchased Composer XE 2013 SP1 (C,C++ and Fortran) update 1  after mooving to OS X Maverick and Xcode 5.0.1.
It seems to have installed properly i.e. files are at the right location i.e. /opt/intel/... , the command line works, but it seems Xcode 5.0 does not "see" the compiler.  Whenever I build and try to execute I get the : SBTarget invalid.  I tried to re-install the compiler , without success.
Anyone could help?
Ron_Green
It sounds like you need to set up the Build Rule 'Default Fortran rule'.
First, follow steps 1, 2, and 3 here http://software.intel.com/en-us/node/463118 to create a project and add a simple Fortran file.  Don't proceed to the build step as we know this won't work just yet.  Next, set up the Default Fortran Rule:
  1. Select the target you want to change and click Build Rules.
  2. From the Xcode menus, select menu 'Editor' -> menu item 'Add Build Rule'.
  3. Under "Process" selector, change 'Source files with names matching' to 'Fortran source files'.
  4. Under "Using" selector, change "Customer Script" to Intel® Fortran Compiler XE 14.0.
  5. Select the target to be built under Targets.
  6. Now you should be able to build.
Robert_K_
Have previous Intel FORTRAN license (2013). Using trial version for 4 days. Trying to build in Xcode -- to see if it works, and how it works. FLEXlm license error. I will assume it doesn't work. On to PGI and ABSOFT to find out if their compilers work with Xcode 5.
Steven_L_Intel1
License error has nothing to do with Xcode. Our current compiler does work with Xcode 5. If you need help with licensing, please ask in our licensing forum.
