Problem with function call in ifort
Balamurugan_R_
Dear all,
Iam working on linpack benchmark where in i need to supply a high resolution timer function. The intrinsic function second() does not provide the required resolution. So i had to use a function based on gettimeofday() function. The function was written in C and was compiled using gcc to create a *.o file.
The fortran program was modified to use the call the c functions binary object. All was working fine except that when the function is called it returns some weird results in the main program but the function itself seems OK.
I am attaching the code and the results here.
FORTRAN CODE:
c The program simulates the linpack second function call at its simplest form.
c The linpack code cannot be changed in any form as it is said in the site
c
PROGRAM b2
double precision :: t1,t2
t1=second1()
c
c DO SOME JOB
c
c elapsed_time =second1() - t1
c print elapsed_time
c
print *,"FORTRAN: MAIN CALL:",t1
END
c
c END OF PROGRAM b2
c
double precision function second1()
implicit none
external mysecond
double precision :: v1,v2
c making a call to the external c function
call mysecond(v1)
v2=v1
second1=v2
print *,"FORTRAN: AT FUNCTION CALL:",v1
print *,"FORTRAN: CHECK ASSIGNMENT:",v2
RETURN
end
C CODE:
#include
#include
#include time.h>
double mysecond_(double *val)
struct timeval tv;
gettimeofday(&tv, NULL);
*val = tv.tv_sec + tv.tv_usec / 1.e6;
printf("VALUE FROM C:%f ",*val);
RESULT OBTAINED:
[root@master tests]# ifort b2.f mysecond.o
[root@master tests]# ./a.out
VALUE FROM C:63937.754206
FORTRAN: AT FUNCTION CALL: 63937.7542060000
FORTRAN: CHECK ASSIGNMENT: 63937.7542060000
FORTRAN: MAIN CALL: 3.315236911126272E-018
VALUE FROM C:63945.945295
FORTRAN: AT FUNCTION CALL: 63945.9452950000
FORTRAN: CHECK ASSIGNMENT: 63945.9452950000
FORTRAN: MAIN CALL: 1.71327996253967
The value from the C program is returned to the Fortran function successfully but not to the main program that is calling the function. What could be the problem?
Bala
You have to declare second1 as double precision in the main program.
Balamurugan_R_
Dear Sir,
Thank you! i have another query.
Is there any option with the compiler to declarea function withinthe code as external. The problem is that the external function namehas a conflict with the intrinsic function and the rule to benchmark is that the code shouldnot be changed.
is it possible?
Balamurugan.R
The EXTERNAL statement declares a name as external. Which intrinsic function are you having a problem with?
Balamurugan_R_
Dear Sir, The problem is that i have to benchmark a machine with Xeon DP on brandon board. Iam to use the linpack benchmark. For n=100 matrix i have to supply a external second function to time the loop execution time. I have written a gettimeofday() function with c and the object file of the c code is compiled with the fortran program using ifort to create the executable. In the fortran code the second function is not declared external. So, is there any way that i can call the external c function from the fortran code without changing the fortran code. Possibly a complier option or some addtions in c code Thank you Balamurugan.R
bpichon
Try to use the Fortran intrinsics related to timing :
TIME_AND_DATE( ... ) for elapsed time
CPU_TIME ( ... ) for runnig time
At my opinion, it is more simple to use Fortran intrinsics to external C function to do the same thing !
There is also SYSTEM_CLOCK as an intrinsic, which returns elapsed time.
TimP
SYSTEM_CLOCK() in ifort has some interesting behaviors, depending on argument data type. It looks difficult to take advantage of these, while retaining some degree of portability to other compilers, which may have only a 32-bit (default integer) version.
The argument kind just determines what the resolution is. If you use the arguments to get the count rate and count max, you can write portable code using it.
