Problems in reading data file T.T
harry27606
This is the simplified logic of the part that I am working on in my program.
There is a main input file with the extension of *.dat
1. When my program find the character string transient boundary condition (TBC) in it,
2. program looks for *.chm data file.
a. If there is no *.chm file, then stop and print error message to the screen/output file.
b. If *.chm file exists,
i. Open/read it
ii. Calculate transient boundary chemistry
This is what I am trying to do. At this point, even though I have TBC in input file and dont have *.chm, my program keep calculating other things. It must stop and print error message!!!
I think there must be very simple (and stupid T.T) mistakes, but I cannot find it. Please take a look at my source file and give me some suggestions. Thanks.
c ----------------------------------------------------------------------
c subroutine initchm
c
c written by: Harry Kim - July __, 2004.
c
c variables have already declaired in other modules or subroutines
subroutine initchm
use gen
use parm
use chem
implicit real*8 (a-h,o-z)
character subsection
logical found_subsection
external findstrg, intpolchm, opnchm
c assign transient boundary chemistry
subsection = 'transient boundary chemistry'
call findstrg (subsection,itmp,found_subsection)
if (found_subsection) then
update_chm = .true.
c else
c return
end if
c open file containing transient boundary chemistry (TBC) data
c and read initial boundary chemistry data
if (update_chm) then
call opnchm
c interpolate time-dependent chemistries on grid
call intpolchm
else
c goto 999
return
end if
c debugging information
info_debug = 0
c transient boundary chemistry
do ichem = 1,nchm
write(idbg,*) 'trschm(ichem) ',trschm(ichem)
end do
if (info_debug.gt.1) then
stop
end if
999 write(ilog,*) 'SIMULATION TERMINATED'
write(ilog,*) 'file ', prefix(:l_prfx)//'.chm missing'
stop
return
end
Message Edited by Harry27606 on 07-08-2004 12:58 AM
Jugoslav_Dujic
Valued Contributor II
But you didn't show us anything about how you open the .chm file?
You can test existence and open the file if OK using:
Code:
OPEN(Some_unit, file="Some_File", STATUS="OLD", IOSTAT=iError)
IF (iError.NE.0) THEN
   Stop "File "//"Some_File"//" does not exist"!
END IF
Jugoslav
P.S. Your posted source code will look much better if you use "SRC" button (but it will work only on Internet Exploder).
harry27606
You are right. This is the next subroutine... If you have any suggestion, please let me know. Thanks.
Code:
c subroutine opnchm
c
c open *.chm file containing transient boundary chemistry
c
c
c last modified:
c
c definition of variables:
c
c I --> on input   * arbitrary  - initialized  + entries expected
c O --> on output  * arbitrary  - unaltered    + altered
c
c        I O
c passed:    -
c
c common:
c gen.f:    integer*4:
c           ----------
c           ichm               = unit number, transient boundary
c                                chemistry                            - +
c chem.f:   real*8:
c           -------
c           dt_chm             = time increment in transient boundary - +
c                                chemistry file
c           chm_read           = time to read next boundary          - +
c                                chemistry
c           schm(nit)          = time steps of specified input
c                                chemistry
c local:    integer*4:
c           ----------
c           nchm               = number of components related to     - +
c                                chemistry input
c           it                 = counter (inlet chemistry points)
c           nit                = number of input time (tbc)
c
c           ----------
c           logical:
c           --------
c
c           character:
c           ----------
c
c external:  mem_chm = allocate memory for one-dimensional arrays
c                       of size nchmp
      subroutine opnchm
      use parm
      use gen
      use chem
      integer it
      external mem_chm
c  define unit number
      ichm = 17
      open(ichm,file=prefix(:l_prfx)//'.chm', err=999, status='old')
      read(ichm,*,err=998,end=998) time_chm
c     open(ichm,file=prefix(:l_prfx)//'.chm',err=999, status='old')
c     open(ichm,file=prefix(:l_prfx)//'.cbcvs',err=997, status='old')
c  read time interval, number of data points and associated depths
c  and allocate memory
      read(ichm,*) dt_chm, nit
      call mem_chm
      backspace(ichm)
      read(ichm,*) dt_chm, nit, (schm(it),i=1,nit)
      chm_read = dt_chm
c  read initial input boundary chemistry data
      read(ichm,*) (chm(it),it=1,nit)
998   write(ilog,*) 'SIMULATION TERMINATED'
      write(ilog,*) 'error reading file ', prefix(:l_prfx)//'.chm'
      stop
      stop
      return
      end
Jugoslav_Dujic
Code looks OK to me -- are you positive that the file doesn't exist? (You probably want a RETURN before label 998, but that's not the issue at the moment).
In any case, you can debug it -- place a breakpoint (F9) at e.g. OPEN line, start debugger (F5), then step-by-step (F10) to see what's going on.
Jugoslav
