29273 Discussions
Problems with real value translation Dlg Win32
ileao1
I wrote a program in CVF win32 Template, using dialog boxes, and i come across with some problems related to the translation of characters strings into real values.
Here is a code sample:
character(80) text
integer ioint
A0 real
integer(4) iret
case (WM_COMMAND)
if (LoWord(wParam) .EQ. IDC_EDIT_A0) then
iret = GetDlgItemText(dlg, IDC_EDIT_A0,text,len(text))
read(text,*,iostat = ioint) A0
endif
if i highlight all the numbers in the edit box and write the new value over the old, the translation do not proceed, the variable A0 keeps its old value.
What should i do? anybody knows?
ileao
Steven_L_Intel1
My guess is that the READ is failing - possibly because of the NUL in the string which I think will be returned by GetDlgItemText. What is the value of ioint after the READ? What is the contents of variable TEXT before the READ?
Steve
ileao1
Before typing in the editing box the values were
before
Co = 6.2, ioint = 0 and text=' '
EDIT BOX = 20 [entered]
read(text,*,iostat = ioint) Co
after
text = '20 '
ioint = 59
Co = 6.2 [Unchanged]
I really dont know why!!!!!!! Read produced no effect.
ileao
Steven_L_Intel1
Error 59 is "List-directed I/O Syntax Error", which is what I expected. The READ is failing and thus doesn't change the variable.
I'll bet that after the 20 is a NUL. You need to adjust the length of TEXT to eliminate the NUL. One way is this:
i = index (text,char(0)) - 1
text = text(1:i)
then do the read.
Steve
ileao1
Steve.
I dont if it's becouse i'm using the dfwina module, but the INDEX command seems to fail.
C:TEMPCVF - USER MADE Examplesgenesiswin32DATA.f90(318) : Error: This name has not been declared as an array or a function. [INDEX]
i = INDEX (co_text,char(0)) - 1
Steven_L_Intel1
INDEX is an intrinsic, and I don't know of anything in DFWINA that would pose a conflict. Perhaps you have INDEX declared explicitly elsewhere?
Steve
ileao1
Steve
Thank you very very much. It runs softly...!! You were right.
May be you could help me in another problem. Ill post right now.
ileao.
