29277 Discussions
Procedure pointer not assumed to be pure
Weiss__Christian
This code snippet does not compile with ifort version >= 19 (but does e.g. with gfortran 10):
module test
  type test_t
    procedure(), pointer, nopass :: do_something => null()
  end type test_t
  type(test_t) :: this_test
contains
  pure subroutine check ()
    call this_test%do_something()
  end subroutine check
end module test
With error message "Any procedure referenced in a PURE procedure, including one referenced via a defined operation or assignment, must have an explicit interface and be declared PURE. [DO_SOMETHING]"
This error can be avoided by defining an explicit interface:
  interface
    pure subroutine foo()
    end subroutine foo
  end interface
  type test_t
    procedure(foo), pointer, nopass :: do_something => null()
  end type test_t
I found out that in version 19, the treatment of procedures as pure has been changed (https://software.intel.com/content/www/us/en/develop/articles/intel-fortran-compiler-191-for-linux-release-notes-for-intel-parallel-studio-xe-2020.html#changed_comp_behaviour), but this deals with intrinsic procedures, especially c_f_procpointer.
At first glance, this looks as though the implicit interface assumed for "()" has no pure implementation. I would like to know if this behavior is intended. I could not find any further specifications in the Fortran standard, but maybe I did miss something?
FortranFan
@Weiss__Christian ,
Based on my understanding, gfortran does not conform to the Fortran standard with the case you have posted.  Note the standard requires a PURE procedure to have an explicit interface.  And the standard does not permit a reference to an IMPURE subroutine in a pure procedure.
Steve_Lionel
The standard is quite clear here:
"C1595 Any procedure referenced in a pure subprogram, including one referenced via a defined operation, defined assignment, defined input/output, or finalization, shall be pure.
The form of a procedure reference is dependent on the interface of the procedure or procedure pointer, but is independent of the means by which the procedure is defined. (15.5.1p1)"
It does not matter whether the reference is to a procedure name or procedure pointer - if the reference is in a pure procedure, there must be an explicit interface that defines it as pure.
In my opinion, gfortran is in error by not diagnosing this.
Weiss__Christian
Thank you for these answers.
