29594 Discussions
Program Exception - array bounds exceeded
YenShih_C_
I have a problem while running a fixed format Fortran program.
I use IMSL to calculate a integral equation: F(T)=exp(-Ea/T) dT, where Ea is a 5*3 matrix of random number.
Somehow the integral equation in the real function F(T) can't read the value Ea which is defined in main program.
When I execute the program, it shows "forrtl : severe <161> : Program Exception - array bounds exceeded"
Therefore, I would like to ask how to read the value from main program and execute successfully.
Thank you!
Here is the entire program,
program main
    use imsl
    implicit real*8 (a-h,o-z)
    integer NOUT
    real, external :: F
    real D,U
    real, parameter :: errabs = 1E-5
    real, parameter :: errrel = 1E-5
    real ans, err
    real Ea(12,12)
    common Ea,i,k
    namelist/limit/No_of_agen,No_of_comp
    D=0
    U=3
    No_of_agen=5
    No_of_comp=3
! initail random Ea
    Do k=1,No_of_agen
      Do i=1,No_of_comp
        call random_number(rn01)
        Ea(k,i)=10*rn01
        write(*,*) Ea(k,i)
      end do
    end do
! integral of each Ea
    Do 10 k=1,No_of_agen
      Do 20 i=1,No_of_comp
        ans=0
        Call QDAGS (F, D, U, errabs, errrel, ans, err)
        write(*,*) ans
20   continue
10  continue
    end
    real function F(T)
    real Ea(12,12)
    real T
    common /part1/ Ea,i,k
    F = EXP(-Ea(k,i)/T)
      write(*,*) Ea(k,i)
    return
    end function
mecej4
You have two different common blocks. The one in the main program is blank common, and the one in the subroutine is labeled /part1/ . Make the two blocks the same.
If you intend to call QDAGS using the implicit (F77) interface, do not have a USE IMSL... statement in the caller. The F95+ interface has the RESULT variable as the fourth argument, whereas the implicit interface contains ERRABS in that position.
YenShih_C_
Thank you so much!
The problem has been solved!
Thank you!
