29597 Discussions
Program Exception - array bounds exceeded
YenShih_C_
I have a problem while running a fixed format Fortran program.
I use IMSL to calculate a integral equation: F(T)=exp(-Ea/T) dT, where Ea is a 5*3 matrix of random number.
Somehow the integral equation in the real function F(T) can't read the value Ea which is defined in main program.
When I execute the program, it shows "forrtl : severe <161> : Program Exception - array bounds exceeded"
Therefore, I would like to ask how to read the value from main program and execute successfully.
Thank you!
Here is the entire program,
program main
    use imsl
    implicit real*8 (a-h,o-z)
    integer NOUT
    real, external :: F
    real D,U
    real, parameter :: errabs = 1E-5
    real, parameter :: errrel = 1E-5
    real ans, err
    real Ea(12,12)
    common Ea,i,k
    namelist/limit/No_of_agen,No_of_comp
    D=0
    U=3
    No_of_agen=5
    No_of_comp=3
! initail random Ea
    Do k=1,No_of_agen
      Do i=1,No_of_comp
        call random_number(rn01)
        Ea(k,i)=10*rn01
        write(*,*) Ea(k,i)
      end do
    end do
! integral of each Ea
    Do 10 k=1,No_of_agen
      Do 20 i=1,No_of_comp
        ans=0
        Call QDAGS (F, D, U, errabs, errrel, ans, err)
        write(*,*) ans
20   continue
10  continue
    end
    real function F(T)
    real Ea(12,12)
    real T
    common /part1/ Ea,i,k
    F = EXP(-Ea(k,i)/T)
      write(*,*) Ea(k,i)
    return
    end function
mecej4
You posted the same message in the Intel Fortran for Windows forum. I replied there.
YenShih_C_
Yes, I posted here first and found that it's wrong zone.
However, I don't know how to delete.
Therefore, I post again in the windows zone.
Sorry and thank you all!
mecej4
What you did is not uncommon among new users, who may be unfamiliar with the organization of these forums.
If you want a post of your deleted, add a comment at the end addressed to MODERATOR or, if that is not allowed (typical for the first post in a thread), add a new "response" simply requesting that the thread be moved or removed, as appropriate. Alternatively, you may send a private message to Kevin D. or one of the other Intel people (their name usually contains a "(Intel)" suffix.
Kevin_D_Intel
I intentionally did not delete this post earlier because it has value in this forum too (its not Windows specific) and given some may only search this forum. I just added the cross reference for convenience of others.
mecej4 is correct, we'll happily remove posts as requested. I think this one is fine though.
YenShih_C_
Thank you! Now I know how to deal with it.
Sincerely, thank you all!
