Puzzled by console line length
OP1
New Contributor III
This code (compiled with 17 Update 1)
PROGRAM P
USE ISO_FORTRAN_ENV
IMPLICIT NONE
INTEGER :: RECLENGTH
INQUIRE(UNIT=OUTPUT_UNIT,RECL=RECLENGTH)
WRITE(OUTPUT_UNIT,'(I4)') RECLENGTH
WRITE(OUTPUT_UNIT,'(A)') '<------ This character string is exactly 80 characters long, believe me! ------>'
WRITE(OUTPUT_UNIT,'(A)') 'Oops!'
END PROGRAM P
when run in a console window with a 80-character long line, produces the output:
 132
Oops!
Why is there a blank line between the two lines of text?
Steve_Lionel
I don't see that:
D:\Projects>t.exe
 132
Oops!
Arjen_Markus
It may be a consequence of the terminal/console detecting that the line was written up to the end of the visible line and therefore inserting a carriage return/line feed.
andrew_4619
So if you 80 char string is 85 long it it wrapping at 80?
OP1
New Contributor III
Yes, it the string is 85 long it will wrap at 80. I am puzzled by the fact that when 80 long it 'wraps' and prints out a blank line. The RECL is also ignored, independently of what the /wrap-margin compiler option is (if the console is wider that 132 characters no wrapping happens).
Arjen may be onto something... I am not sure how to disable this though. It seems that Steve cannot reproduce this.
This is purely cosmetic of course, but a bit disconcerting. I oftentimes output to the console 'delimiter strings' which have the width of the console, to keep the output of my code neat; and now it is inserting a blank line afterwards. Strange.
Steve_Lionel
I don't think it's Intel Fortran doing the wrapping. The options you mention apply to list-directed output only.
jimdempseyatthecove
The line wrap when text printed hits right margin (80 in this case), followed by anything, even non-advancing character (except maybe back space), will line advance (depending on terminal emulator). This includes CR, LF, CRLF.
This has been with us since the 1980's. Think of it as a "feature".
Jim Dempsey
jimdempseyatthecove
BTW
Windows, in text edit box/window has an equally goofy line advance issue depending on if window has vertical scroll bar and/or boarder design.
Jim Dempsey
andrew_4619
You can set and control console attributes using windows api routines but some work is involved.
OP1
New Contributor III
Thanks to all for the answers - yes, it looks as if this is a Windows console behavior that cannot be controlled "easily" from my code.
