/QaxW versus /QaxN
Ilie__Daniel
Hello!
Could anybody tell me what is the difference between /QaxW and /QaxN options?
The documentation states the following:
  • for /QaxW: Can generate specialized code paths for SSE2 and SSE instructions for Intel processors, and it can optimize for Intel Pentium 4 processors and Intel Xeon processors with SSE2.
  • for /QaxN: Can generate specialized code paths for SSE2 and SSE instructions for Intel processors, and it can optimize for Pentium 4 processors and Intel Xeon processors with SSE2.
Thank you for your time.
Kind regards,
Daniel.
TimP
As Steve pointed out, there is a possibility /QaxN will produce better optimized code in the SSE2 path for Intel CPUs. If you want to run exclusively on CPUs which support SSE2, including AMD CPUs, you would prefer /QxW. For running exclusively on SSE3, if you see an advantage in including SSE3 instructions, you could use /QxO.
Steven_L_Intel1
Tim, I don't believe that to be the case. As far as I know, AMD processors will always take the "generic" path when a /Qax option is used. You can set this generic path to be SSE2 by also using /QxW, or SSE3 with /QxO.
The difference between W and N is that N requires Intel CPUs and enables some additional optimzations. There's no point in using /QaxW - you may as well use /QaxN.
