29376 Discussions
Quickwin program freezes on Windows 7 x64
Reinaldo_Garcia
When the program ends and displays the message "...Exit window?", if you click No, the window freezes.
The same program works just fine in Vista x64/XP.
I have Windows 7 Ultimate x64 and compiler 11.1.035.
Any suggestion?
R//G
[Edit by Steve Lionel (Intel) - for information on this problem and to obtain a fix, please readIntel Visual Fortran QuickWin applications freezing]
hkausl
Works fine now. Thanks
David_F_9
I may need to start a new thread about this, but has this freezing behavior been seen in any other types of FORTRAN executables?
I have a FORTRAN DLL that is called from a VB.NET program that has been freezing on a few Windows 7 64-bit machines. We have not been able to reproduce the issue here (both were developed on Win7 x64).
The DLL is not Quickwin, but it does have callbacks to the VB.NET program for screen output (shown on screen via a VB Rich Text Box).
Thanks for any help.
Wendy_Doerner__Intel
Valued Contributor I
Yes it would be best to start a new thread with a title that refelects it. Can you include details on what you are seeing and even a test case that reproduces if possible. I have not seen or heard of these problems with Visual Basic caused by the compiler and this issue applies to Quickwin library only.
Wendy
Attaching or including files in a post
