29253 Discussions
RPM problem Installing IFC on Slackware 9.1
Anonymous6
Question from a linux&IFC noob:
I'm trying to install IFC on a linux-box with Slackware 9.1. After starting install.sh I get the message:
RPM is not installed or not functioning correctly.
Well I think it is and it does. Using only "rpm" as command it displays the Usage options. I read somewhere that I should add --force to the rpm command in install.sh. Can this solve my problem? And if so, can someone tell me in which line I should do this? The rpm command occurs several times. in install.sh.
thanks in advance
Peter Weiland
The Netherlands
Intel_C_Intel
Sorry about bumping this topic but is there nobody out there who can help me? Not even @Intel?
Thx,
Peter Weiland
Steven_L_Intel1
Slackware is not one of the distributions we claim support for, and we don't even test it as far as I know. You may want to try the tip given in the release notes (and in the FAQ section of our support web site) on installing not as root - I think this bypasses RPM as well.
Another thought - some older versions of RPM have troubles like this, see if there's an updated binutils package you can install.
