Random_number
mohammad_b_
Hi
I use ifort compiler. in my code i need random integer number between 1<= i <=64.
i used random_number(x) and it is between 0<x<1. then for my purpose i use this transformation
i = floor(64*x) + 1
but when i use this transformation sometimes i = 65. after debug my code i find that when x = 0.9999
this mistake is happened.I guess the problem is due to rounding error. how to avoid from this mistake?
Laura_S_3
That seems like very unexpected behavior. I find this very concerning since I depend on floor working properly in my programs.
Can you provide a small reproducer? Also, what version of compiler?
mecej4
Indeed, you need to provide a reproducer. The only way for floor(64*x) to equal 64 is for x to be equal to 1, and RANDOM_NUMBER is supposed to never return 1; call random_number(x) is supposed to return x such that 0 <= x < 1. Here is a test program that does not use RANDOM_NUMBER that you can use to test your compiler:
program tstflr
implicit none
real x,dx
integer i,ix
dx=16.0*epsilon(x)
do
   x = 1.0 -dx
   if(x == 1.0)stop
   if(floor(64*x) >= 64)then
      write(*,*)'When x = ',x,' floor(64*x) exceeds 63'
      stop
   end if
   write(*,'(1x,2ES15.8)')x,dx
   dx=0.5*dx
end do
end program
The output that I get from it:
  9.99998093E-01 1.90734863E-06
  9.99999046E-01 9.53674316E-07
  9.99999523E-01 4.76837158E-07
  9.99999762E-01 2.38418579E-07
  9.99999881E-01 1.19209290E-07
  9.99999940E-01 5.96046448E-08
This shows that x went through several values > 0.9999 before it became indistinguishable from 1.0 in single precision.
mohammad_b_
my compiler version is 15.0.0      and  20140723
this is my code and if this mistake don't occur then in line 56 n1 must be printed as 0
but n1 printed as 2
program simple_ising
  implicit none
  integer, parameter :: n = 64
  real, parameter :: t = 2.269
  integer :: s( 1:n , 1:n )
  real :: x, y
  real :: prob
  real :: finish, start
  integer :: i, j, ix, iy, r, l, u, d, mag, m1, mn, delta, en, n1
  open(unit=1, file='a3')
  call cpu_time(start)
  mag = 0
  en = 0
!   intial state is random
  call random_seed
  do i = 1, n, 1
    do j = 1, n, 1
        s(i,j) = -1
        if ( x .gt. 0.5 ) then
          s(i,j) = 1
        end if
    end do
  end do
  mag = sum(s)
  print*,mag/real(n*n)
    n1=0
  do i = 1, n*n, 1
    do j = 1, n*n, 1
      ix = floor( n*x + 1.0 )
      call random_number(y)
      iy = floor( n*y + 1.0)
      r = ix + 1 ; l = ix -1 ; u = iy + 1 ; d = iy - 1
      if ( ix + 1 .gt. n ) r = 1
      if ( ix - 1 .lt. 1 ) l = n
      if ( iy + 1 .gt. n ) u = 1
      if ( iy - 1 .lt. 1 ) d = n
      if ( ix .gt. n .or. iy .gt. n) n1=n1+1
      mn = s( r, iy) + s( l, iy) + s( ix, u) + s( ix, d )
      delta = mn * s( ix, iy )
      !delta=0
      prob = exp((-2*delta)/t)
      !prob=1.1
      if ( x .lt. prob ) then
         s(ix,iy) = -s(ix,iy)
         en = en + 2*delta
         mag = mag + 2*s(ix,iy)
      end if
    end do
    write(1,*) i, mag/real(n*n), en/real(n*n)
    !pause
  end do
  call cpu_time(finish)
  print*,n1, (finish-start)
end program simple_ising
mecej4
On Line-48, instead of ix = floor( n*x + 1.0 ), use ix = floor( n*x) + 1. Similarly for iy on Line-48. The following test program illustrates the difference and the importance of truncation immediately after multiplying and before adding 1:
program tflr
implicit none
integer ix1,ix2
real x
x=nearest(1.0,-1.0)
ix1=floor(64*x+1)
ix2=floor(64*x)+1
print *,ix1,ix2
end program
Note that the FLOOR function does not in general have the property
     floor(A + B) = floor(A) + floor(B)
and, therefore, you have to write your program accordingly.
mohammad_b_
program tflr
implicit none
integer ix1,ix2
real x
x=nearest(1.0,-1.0)
ix1=floor(64*x+1)
ix2=floor(64*x)+1
print *,ix1,ix2
end program
yes. but in this case this property is true
mecej4
mohammad b. wrote:
Quote:
mecej4 wrote:
On Line-48, instead of ix = floor( n*x + 1.0 ), use ix = floor( n*x) + 1. Similarly for iy on Line-48. Note that the FLOOR function does not in general have the property
No, it is not; if you can advance logical arguments to support that claim, I'll revise my opinion. On the other hand, making the changes (to replace floor(x*64.0+1.0) by floor(x*64)+1, and similarly with y) to your program in #4 and running shows that my explanation is correct (of how ix or iy exceeded the intended range). The result displayed for n1 is 0 after the changes, but you may see various non-zero values in your original program. If you wish to track down this issue more fully, you may set the random number seed to a predetermined value at the beginning of the program.
