Re: incorrect standards warning?
Steven_L_Intel1
Yes, you did mention this before. Please keep in mind that this forum is not a technical support channel - if you want to report problems and get responses, use vf-support@compaq.com
In this case, I did pass along the test case to a developer for fixing - I haven't looked to see if it is fixed yet, probably is.
Steve
Steven_L_Intel1
Based on my reading of the standard, your two examples are standard-conforming, despite the compiler warnings at present.
Steve
