29651 Discussions
Reading from edit boxes while initializing dialog
meistrv
I have this problem:
I have a SDI application. When it starts I create a dialog:
case(WM_CREATE)
call MainDialogProc
Where the MainDialogProc creates the dialog using DlgModeless function, the dialog subroutine is assigned:
bret = DlgSetSub(gdlg, Dialog_Trans, TransSub).
In the TransSub within the dlg_init section I read some numbers from a file and put them into edit boxes. It works fine. NOW: after reading numbers and filling the edit boxes I would like to make a sum of these numbers, so I call subroutine suma (still within the dlg_init section), that evaluates the sum and writes the result into another editbox.
The subroutine SUMA checks whether there are numbers in the edit boxes (they are), but it says they are not. When I call the subroutine right after the dialog starts by a button click, everything is OK.
It seems to me like the numbers aren't in the editboxes during the dlg_init section. Is there a way how to manage these numbers?
Thanks for your suggestion
Vit
Jugoslav_Dujic
Valued Contributor II
Try calling DlgFlush(Dlg) before calling Suma.
Jugoslav
