Regression in 2025.2
NCarlson
New Contributor II
The following example reproduces a regression in the oneAPI 2025.2 Fortran compiler that I encountered in our production code.
module m1
  character(:), pointer, private :: string => null()
contains
  function get()
    class(*), pointer :: get
    if (.not.associated(string)) allocate(string, source='foo')
    get => string
  end function
  subroutine set(arg)
    class(*), intent(in) :: arg
    select type (arg)
    type is (character(*))
      print *, 'set received string "', arg, '"'
      if (arg /= 'foo') stop 'ERROR!'
    end select
  end subroutine
end module
use m1
select type (s => get())
  print *, 'passing string "', s, '" to set'
  call set(s)
end select
end
It produces the incorrect result
$ ifx intel-20250709.f90
$ ./a.out
 passing string "foo" to set
 set received string ""
ERROR!
The expected output (from 2025.1, for instance) is of course
 set received string "foo"
NCarlson
New Contributor II
A workaround in the main program is to assign S to a local allocatable character variable and pass it instead:
use m1
character(:), allocatable :: ss
  ss = s
  call set(ss)
end select
end
NCarlson
New Contributor II
Ping to someone on the Intel team. This regression still exists in 2025.3.
Igor_V_Intel
Unfortunately, it is still in the latest engineering build. I am escalating to fix it (CMPLRLLVM-74899).
