Hi. I'm having trouble installing ifort 2013 on a ubuntu 12.04 system.
The first time I installed it, it showed several "sh: Syntax error: Bad fd number" messages at the begining of installation. But the installation was done anyway. However, all of the compilervars.sh (and similar) files are zero-length.
I tried the solution provided in http://software.intel.com/en-us/forums/topic/326646
Now there was no Bad fd numberr message, but instead it shows "The Intel(R) Composer XE 2013 for Linux* is already installed." and
the installation cannot be completed.
I tried to ran the uninstall.sh but it still doesn't work. I found a similar problem in http://software.intel.com/en-us/forums/topic/286581
I ran the command rpm -qa | grep intel and found the following files:
intel-openmp-devel-079-13.0-0.i486
intel-compilerpro-vars-079-13.0-0.noarch
intel-compilerprof-common-079-13.0-0.noarch
intel-compilerprof-devel-079-13.0-0.i486
intel-sourcechecker-devel-079-13.0-0.i486
intel-idbcdt-079-13.0-0.noarch
intel-mkl-common-079-11.0-0.noarch
intel-mkl-devel-079-11.0-0.i486
intel-openmp-079-13.0-0.i486
intel-compilerpro-common-079-13.0-0.noarch
intel-compilerpro-devel-079-13.0-0.i486
intel-compilerprof-079-13.0-0.i486
intel-sourcechecker-common-079-13.0-0.noarch
intel-idb-common-079-13.0-0.noarch
intel-idb-079-13.0-0.i486
intel-mkl-079-11.0-0.i486
Should I delete all these files? If so, how am I supposed to do it? As I know, ubuntu is not a rpm-based system. When I try the rpm -e command, it shows:
rpm: RPM should not be used directly install RPM packages, use Alien instead!
Thanks!!
Hello Guys!
I Would like to remove the Intel Composer XE 2013, because i think my installation is not correct, more specific the location, because don't appears the /opt directory. Do You have any idea?
If you lost the uninstall script which installs along with the compiler, try :
rpm -qa|grep intel
sudo rpm -e <rpms associated with the version you want to re-install?
If your distro doesn't use rpm, can your package manager help?
![](/skins/images/DC0E2679F7049B943291D1ED082A478E/responsive_peak/images/icon_anonymous_message.png)
