29654 Discussions
Replicating Save Fortran Environment
Chris_H_3
To Whom It May Concern;
I write to ask whether anyone has a way to replicate the old CVF 'save fortran environment' function.  I have a number of libraries to bind against.  Every time I create I new VS2015 project, I have to add them to the solution.  Is there a way to create a blank template solution that I can copy to a new location and rename so that all the libraries will be present?
Any advice on this is welcome.  Thank you.
Sincerely,
CHobbs
You could construct your own Fortran project that had the desired options, with no source files. Then just copy the .vfproj file into an empty folder (renaming the file to be your desired project name), open the .vfproj file (double-click), rename the project and add your files. When you go to save, it will prompt you to create a solution file.
Chris_H_3
It worked!  Thanks, Steve.  I've been looking for this answer for three years.  Now if I could just get the array visualizer functionality back while debugging...
Did you ask before?
Sorry, Array Visualizer isn't coming back.
Chris_H_3
Dear Steve;
Hello.  I did not ask on the forum.  I used the premier support and asked them.  They did not know the trick you mentioned.
Sincerely,
Chris
