29298 Discussions
Require a particular version/build of the Compiler
Colesky
To whom it may concern,
I have successfully installed the Fortran Compiler and have run problems creating Abaqus Subroutines.
Now - after some debugging efforts - it turns out that what I am wanting to do indeed runs with
Version 19.0.5.281 Build 20190815.
I have version Version 2021.6.0 Build 20220226_000000 - there seems to be some bug for this particular version with Abaqus.
How do I get the earlier version?
Many thanks.
Colesky
Ron_Green
you can download that from your Intel Registration Center account if you have purchased a support entitlement.  It is not available without a license.  More information is HERE
WIth your entitled account, you use the PSXE downloads on Intel Registration center:
Steve_Lionel
May I suggest that first you do some analysis to see if it isn't a compiler bug but rather an error in your code?
Colesky
Steve,
I've checked this - the User Subroutine compiles and runs in both cases but delivers different (correct) results with the Version 19.0.5.281 Build 20190815 of the Compiler.
Colesky
Steve_Lionel
Now find out why. Which calculation gets a different result when compiled with the two versions. How different is the answer?
