Not until the 2003 Fortran standard ReAllocate capability is provided.
The followingshows a (cut down version of a) technique I use a lot usingmodules,pointers and allocatable arrays :
Code:
Module X ! Assign appropriate values to the following 3 integers integer*4 :: InitialSize integer*4 :: CurrentSize integer*4 :: Increment ! Pointer and target arrays real*8, pointer :: zlevel(:) ! Z Level real*8, allocatable, target :: zlevel_a(:) ! Z Level real*8, allocatable, target :: zlevel_b(:) ! Z Level CONTAINS subroutine AllocateZLevel ! having set an appropriate value for InitialSize allocate(zlevel_a(InitialSize),stat=ierr) ! Point zlevel to zlevel_a zlevel => zlevel_a ! Initialise zlevel to some appropriate starting value zlevel = 0.0.d0 CurrentSize = InitialSize end subroutine AllocateZLevel subroutine ReAllocateZLevel(ierr) osize = CurrentSize nsize = osize + INCREMENT ! Check which array is currently allocated a or b ! Allocate the other with the new size ! Copy the data from old array to the new array ! Point the pointer to the new array if (allocated(zlevel_b)) then allocate(zlevel_a(nsize), stat=ierr) if (ierr == 0) then do i=1,osize zlevel_a(i) = zlevel(i) enddo deallocate(zlevel_b, stat=i) zlevel => zlevel_a endif else allocate(zlevel_b(nsize), stat=ierr) if (ierr == 0) then do i=1,osize zlevel_b(i) = zlevel(i) enddo deallocate(zlevel_a, stat=i) zlevel => zlevel_b endif endif if (ierr == 0) then CurrentSize = nsize endif return end subroutine ReAllocateZLevel end module X
I hope you see the principle anyway. Thedata is referenced throughout the code by zlevel and zlevel points to either zlevel_a or zlevel_bdepending on the calls to ReAllocateZLevel
Les
Sorry for the misinformation. I thought I remembered something about the programmerbeing able to reallocate arrays (in place?)in F2003 I wasn't sure ifthere was a function/subroutine to do it though, or whether it wasan automatic "behind the scene" thing on assignment.
Reading more closelythe document"New features of Fortran 2003" by John Reid I see the use of MOVE_ALLOC.
Thanks Steve for the correction
Les
![](/skins/images/98E68944C1FF703B8AC50091329B92AF/responsive_peak/images/icon_anonymous_message.png)
