29649 Discussions
Runtime error 41, insufficient virtual memory
David_Rowe
Hello, I have a Windows application which runs continuously on an unattended PC (monitoring an industrial process). Normally its memory use is modest, i.e. a few tens of MB. But very occasionally it halts with the following run-time error: "FORRTL Severe (41) Insufficient Virtual Memory. Stack trace terminated abnormally" On inspection in Task Manager, the VM size for the process at the point of failure is much larger than normal - of the order of 1 or 2 GB. (And I assume that's why the stack trace fails). I've inspected the source code, and as far as I can see, every explicit memory allocation via ALLOCATE has a STAT= clause, and so shouldn't produce the run-time error message. I don't know what external circumstances provoke the error, i.e. I can't reproduce it to order. Any suggestions as to what I should do next to diagnose the problem would be appreciated. I'm using IVF 10.1. Thanks, David
The first thing I would suggest is to rebuild with the current 11.1 compiler. You might have a memory corrupter bug in your code somewhere, but this can be hard to find.
