29253 Discussions
SEGFAULT during call to DPOSV from MKL library
lucchem
I am compiling and running the following code:
program bug
      implicit none
      INCLUDE 'mkl.fi'
      integer*4, parameter :: Npart=25
      real(kind=8) :: u(1:Npart), lapackab(1:Npart,1:Npart)
      integer*4 :: i, j
      u=0.2d0
      lapackab=0d0
      do i=1,Npart
          lapackab(i,i)=2d0
      enddo
      call DPOSV('L',Npart,1,lapackab,Npart,u,Npart,i)
      write(*,*) "i=",i
end program
For some reason that I cannot really understand, it dies on segmentation fault during the call to DPOSV.
I compile it using the following command (ifort 2016, MKL 11.3):
ifort -O3 -openmp bug.f90 -o run -I/opt/share/INTEL/mkl/include -L/opt/share/INTEL/mkl/lib/intel64/ -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lm -ldl
and I get the same error both using -O3 and -O0 -g. NOTE: with Lapack 3.6.1, it works. I cannot really understand the origin of this error, do you have any clue?
Thank you.
EDIT: I got a nice hint. Basically, I was linking the mkl_intel_ilp64 library while using 4 bits integers. I just changed library to mkl_intel_lp64 and the problem is gone.
