29641 Discussions
Using larger array in a Fortran subroutine
zhang__darrel
My Fortran code is below(test.f):
subroutine sub(n1,n2,wa)
implicit none
integer, intent(in)  :: n1, n2
real(4), intent(inout) :: wa(1_8:1_8*n1*n2)
integer(8) :: i, j, ms
print*, 'in sub, 1_8*n1*n2=', 1_8*n1*n2
print*, 'in sub, size of wa:', size(wa,kind=8)
ms=0
!$omp parallel default(shared) private(i,j,ms)
!$omp do
    do i=1, n1
    do j=1, n2
       ms=(i-1)*n2+j
       wa(ms)=ms*1.d0
    enddo; enddo;
!$omp end do nowait
!$omp end parallel
print*, 'size of wa:', size(wa,kind=8)
return
end subroutine sub
program main
implicit none
integer, parameter :: n1=2**11,n2=2**20
real(4), allocatable :: wave(:)
integer :: ierr
integer(8) :: i
allocate(wave(1_8*n1*n2), stat=ierr)
!$omp parallel default(shared) private(i)
!$omp do
     do i=1_8,1_8*n1*n2
       wave(i)=0.d0
     enddo
!$omp end do nowait
!$omp end parallel
print*, 'in main, size of wave:', size(wave,kind=8)
call sub(n1, n2, wave)
print*, wave(1_8*n1*n2)
deallocate(wave, stat=ierr)
end program main
n1 and n2 can be larger, and make sure that n1*n2 is an long integer (>2**31-1). I just want to test how to use very large array in a subroutine.
i compile with intel fortran 2015 and run on centos 7.3.1611.
I compile with: ifort -openmp -CB test.f.
the array wa in subroutine sub will make an error if I use -CB option for checking bound of an array.
This is the error information:
in main, size of wave: 2147483648
in sub, 1_8*n1*n2= 2147483648
in sub, size of wa: 0
forrtl: severe (408): fort: (2): Subscript #1 of the array WA has
value 108003329 which is greater than the upper bound of -2147483648.
the number of value in the error information is random.
When I declare wa in subroutine as real(4), intent(inout) :: wa(1), the program will run well.
If i complie with: gfortran gfortran -fopenmp -fbounds-check test.f, the program also run well.
Can someone tell me why?
