29657 Discussions
SIZE function on an ALLOCATABLE array
Jon_D
New Contributor II
The following code prints out 10 as the size of the ALLOCATABLE array after the array is deallocated. Is this the correct behavior or a compiler bug? I am using the latest version of the Intel Fortran compiler.
Thanks for any clarification.
PROGRAM Main
    IMPLICIT NONE
    INTEGER,ALLOCATABLE :: iTestArray(:)
    WRITE (*,*) SIZE(iTestArray)
    ALLOCATE (iTestArray(10))
    DEALLOCATE (iTestArray)
END
It's your error for calling SIZE on an unallocated array. The result of that is undefined.
andrew_4619
You should use the function allocated(itestarray)
