29276 Discussions
SPREAD and UNPACK not accepted in constant expressions
Harald
Hello all, it appears that SPREAD and UNPACK are still not accepted in constant expressions: program ifort_unpack implicit none integer, parameter :: set(5) = (/ 11,12,13,14,15 /) integer, parameter :: sel(2) = (/ 12,14 /) logical, parameter :: mask(size(set)) = & any (spread (set,2,size(sel)) == & spread (sel,1,size(set)), dim=2) integer :: i integer, parameter :: idx(size(set)) = & unpack (vector = (/ (i,i=1,size(set)) /), & mask = mask, & field = 0 ) print *, idx end program ifort_unpack % ifort -V ifort-unpack.f90 Intel(R) Fortran Compiler XE for applications running on IA-32, Version 13.0.1.117 Build 20121010 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. FOR NON-COMMERCIAL USE ONLY Intel(R) Fortran 13.0-2074 ifort-unpack.f90(6): error #6263: This intrinsic function is invalid in constant expressions. [SPREAD] any (spread (set,2,size(sel)) == & ------------^ ifort-unpack.f90(7): error #6263: This intrinsic function is invalid in constant expressions. [SPREAD] spread (sel,1,size(set)), dim=2) ------------^ ifort-unpack.f90(10): error #6263: This intrinsic function is invalid in constant expressions. [UNPACK] unpack (vector = (/ (i,i=1,size(set)) /), & -------^ compilation aborted for ifort-unpack.f90 (code 1) I could not find any corresponding restriction in the F2k3 and F2k8 draft, so I assume that there should be none. (If I remember correctly, it was illegal for SPREAD in F95) Harald
Steven_L_Intel1
This is a F2003 feature we have not completely implemented yet - transformational intrinsics in constant expressions.
Harald
I just checked the above code with
Intel(R) Fortran Compiler XE for applications running on IA-32, Version 15.0.0.090 Build 20140723
and still get the above error messages.  Do you envisage when there will be progress?
Harald
Steven_L_Intel1
There are a handful of intrinsics not yet implemented, but we're working to get those done. Do you have an application using these?
Harald
I find SPREAD very convenient, but cannot yet use it in constant expressions for portable code.  Since it works with most other Fortran compilers, I tend to forget this.
UNPACK is a little bit exotic, and there are probably few situations where it needs to be evaluated at compile time.
Harald
