Steve Lionel (Intel) wrote:
This is a F2003 feature we have not completely implemented yet - transformational intrinsics in constant expressions.
I just checked the above code with
Intel(R) Fortran Compiler XE for applications running on IA-32, Version 15.0.0.090 Build 20140723
and still get the above error messages. Do you envisage when there will be progress?
Harald
There are a handful of intrinsics not yet implemented, but we're working to get those done. Do you have an application using these?
I find SPREAD very convenient, but cannot yet use it in constant expressions for portable code. Since it works with most other Fortran compilers, I tend to forget this.
UNPACK is a little bit exotic, and there are probably few situations where it needs to be evaluated at compile time.
Harald
