Scope of IMPLICIT NONE
Andrew_Smith
Valued Contributor I
If we have IMPLICIT NONE in a module does its scope extend to the procedures defined in the module? It does in IVF but I do not know what the standard specifies. The IVF help file is silent on this.
Arjen_Markus
It _is_ part of the standard, I do not think the online help should replicate that.
Arjen
Andrew_Smith
I was using local help. I think the local and online help should replicate the standard. Intel seam to agree because the local help has a section called "Language Reference" which is where IMPLICIT NONE is detailed.
Kevin_D_Intel
The IVF documentation for IMPLICIT states "When IMPLICIT NONE is used, all names in a program unit must be explicitly declared." and under "Program Units and Procedures" defines a "program unit" as one of four types:
Main program
External procedures
Modules
Block data program unit
And the compiler's treament is consistent. Itgenerates an error for the following:
[fortran]module impl
implicit none
contains
  subroutine sub
    a=1
  end subroutine sub
end module impl[/fortran]
$ ifort -c -V sample.f90
Intel Fortran Compiler Professional for applications running on IA-32, Version 11.1 Build 20100806 Package ID: l_cprof_p_11.1.073
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
Intel Fortran 11.1-2755
sample.f90(5): error #6404: This name does not have a type, and must have an explicit type.
a=1
compilation aborted for sample.f90 (code 1)
Kevin_D_Intel
Just to add about knowing what the Standard specifies,as per the IVF Language Reference section Overview it states "This document contains the complete description of the Intel Fortran programming language, which includes Fortran 95, Fortran 90, and many Fortran 2003 language features. It contains information on language syntax and semantics, on adherence to various Fortran standards, and on extensions to those standards." and further under Language Standard Conformance, it notes that Intel Fortran specific extensions are displayed in the Language Reference manual in "blue" shaded text.
So the Language Reference section does help one know what the various Fortran Standards specify and what is an Intel specific extension.
JVanB
Valued Contributor II
More interesting if you override IMPLICIT NONE in subroutine sub with IMPLICIT INTEGER(A). Then the file is conforming but not if also the line b=1 appears in subroutine sub.
