29336 Discussions
looking for library archiving tool xiar d
intelgeli
Hello
We are using the Intel Fortran compiler on our cluster with Starcd. The jobs with user user routines are exiting with the error "looking for library archiving tool xiar d" and comment that the library is usually installed with the compiler. Is this an Intel library that I have to install separately to the compiler?
Error message;
PNP: Analyzing User coding in "ufile" directory.
PNP: **WARNING** Cannot find required library archiving tool "xiar d".
PNP: ==> This binary utility is normally installed with your C/Fortran compilers.
TimP
Quoting - intelgeli
Hello
Error message;
xiar (archive tool for IPO objects) should be present in the same directory as ifort and icc, a mandatory part of the standard install. If it is present, but missing execute permission, it would not be found even though PATH is set up to include the ifort directory.
Philip_Jones
If you get this error and have the Intel compiler, then you need to add the compiler to your path.
There are two ways of doing this. Note this assuem Intel installed in /users/porting/... so you need to change this for your own installation.
1) In the hardware.ini file you set the variable called INTEL and then STAR-CD will add this to the path and find xiar
platform Linux_x86_64 INTEL=/users/porting/dep/compilers/INTEL/11.1.046
This means that whenever you use setsar to set the STAR-CD version, you set the right Intel version.
2) You add xiar to the path yourself using the relevant provided ifortvars script
sakura<53>which xiar
xiar: Command not found.
sakura<54>source /users/porting/dep/compilers/INTEL/11.1.046/bin/ifortvars.csh intel64
sakura<55>which xiar
/users/porting/dep/compilers/INTEL/11.1.046/bin/intel64/xiar
sakura<56>
