29629 Discussions
Segfault when passing procedure, pointer to function but not when calling function from main program
nousername
My C code:
#include <stdio.h>
#include <stdlib.h>
struct function_struct
  double (* function) (double x);
typedef struct function_struct gsl_function;
gsl_function *function_cinit(double (*func)(double x)) {
    gsl_function *result;
     if (func) {
      printf("Passed Function Not Null\n");
    printf("The size of gsl_function is %zu\n", sizeof(gsl_function));
    result = (gsl_function *) malloc(sizeof(gsl_function));
    result->function = func;
    printf("Res: %f\n", (*func)(2.0));
    if (result) {
      printf("Result Not Null\n");
    return result;
Fortran Code:
module integral
  use, intrinsic :: iso_c_binding
  implicit none
  !Interface to call C function
  interface
     function function_cinit(func) bind(c)
       import
       type(c_funptr), value :: func
       type(c_ptr) :: function_cinit
     end function function_cinit
  end interface
 !Proc pointer interface for arbitrary math function f(x) which is passed to the C function so it can be used in a library that requires
 ! a pointer to a function
  abstract interface
     function rhox(r) bind(c)
       real(c_double), value :: r
       real(c_double) :: rhox
     end function rhox
  end interface
contains
  ! Arbitary function f(x) = x
  function f(x) bind(c)
    real(c_double) :: f
    real(c_double), value :: x
    f = x
  end function f
 !Function passed by name
  function func_init(func)
    interface
       function func(x) bind(c)
         real(c_double) :: func
       end function func
    end interface
    type(c_ptr) :: func_init
    type(c_funptr) :: fp
    fp = c_funloc(func)
    func_init = function_cinit(fp)
  end function func_init
  !Function passed with procedure pointer
  function fp_init(fun)
    procedure(rhox), pointer :: fun
    type(c_ptr) :: fp_init
    fp = c_funloc(fun)
    call c_f_procpointer(fp, fun)
    fp_init = function_cinit(fp)
  end function fp_init
  !C_funptr passed directly
  function cfun_ptr_init(fun)
    type(c_funptr) :: fun
    type(c_ptr) cfun_ptr_init
    cfun_ptr_init = function_cinit(fun)
  end function cfun_ptr_init
end module integral
program bsp
  use integral
  implicit none
  procedure(rhox), pointer :: fptr
  type(c_funptr) :: cptr
  type(c_ptr) :: c_result
  fptr => f
  cptr = c_funloc(fptr)
  call c_f_procpointer(cptr, fptr)
  !This works, calling the cptr after calling c_f_procpointer on c_funptr obtained by using c_funloc
  print *, "Evaluate C Function: ", fptr(2.0_c_double)
  print *, ""
  !This Works f(2.0) = 2.0, valid pointer
  c_result = func_init(f)
  print *,"Passing Function Directly Successful"
  print *, " "
  !This works, calling C function directly from main program passing it the c_funloc of the procedure8
  c_result = function_cinit(cptr)
  print *,"Calling C Function  Directly Successful"
  print *, " "
  c_result = cfun_ptr_init(cptr)
  print *,"Calling C function by Passing c_funptr Successful"
  print *, " "
  !Segmentation Fault 11, calling C function indirectly from function which I pass the Fortran Proc pointer
  c_result = fp_init(fptr)
end program bsp
I'm trying to add to the Fortran GSL interface and simplified the code a bit. I'm not sure why passing the procedure pointer the function makes it not work, but it works if I do it directly in the main function. I've tried it on both ifort and gfortran with the same errors. I have a feeling it's due to pointer indirection or something when I pass it to the function first and then pass that to the C code. I would then use that c_ptr that returns to pass to a GSL integration routine.
nousername
Found the solution. I removed the "pointer" attribute from the "fp_init" function which wasn't working even though I pass it a pointer. I could have just passed a procedure pointer to the first function I had that worked without changing it. However, I'm not sure why this worked. I would still appreciate any explanation.
    !Changed from:
    !procedure(rhox), pointer :: fun
    procedure(rhox) :: fun
    fp = c_funloc(fun)
    !call c_f_procpointer(fp, fun)
