I am a beginner of fortran, now I have a code which debugging with error 7976.
Program test_main
implicit none
integer NP,ele_n,NE,NNE,npt,num
integer,pointer :: ele_concentrate( : ),ele_c( : )
double precision,pointer::vcl( : , : )
interface
subroutine new_node(NP,ele_n,NE,NNE,ele_concentrate,ele_c,vcl,npt,num)
implicit none
integer,allocatable :: ele_concentrate(:),ele_c(:)
double precision,allocatable :: vcl(:,:)
end subroutine new_node
subroutine zhaobian_gj01(NP,ele_n,NE,NNE,ele_concentrate,ele_c,vcl,npt,num)
implicit none
double precision,allocatable ::vcl(:,:)
end subroutine zhaobian_gj01
end interface
call zhaobian_gj01(NP,ele_n,NE,NNE,ele_concentrate,ele_c,vcl,npt,num)
call new_node(NP,ele_n,NE,NNE,ele_concentrate,ele_c,vcl,npt,num)
end
The compiler whines when calling subroutine zhaobian_gj01 and new_node, with error #7976: An allocatable dummy argument may only be argument associated with an allocatable actual argument. (ele_concentrate,ele_c,vcl)
How can I solve this problem? Thanks.
In Fortran, you are permitted to have
a) An allocatable array
b) A pointer, to an allocatable array
These are two different entities (object types). In the first case (allocatable), you have an object that is an array descriptor. In the second case (pointer) your have a pointer (which may be NULL) that points to an array descriptor.
Although your code dereferences each the same, the underlying code is different.
Both arg types should be the same (both allocatable or both pointer to allocatable)
Jim Dempsey
Jim Dempsey
Typically you don't want to declare a dummy argument to be ALLOCATABLE unless you will be changing its allocation status inside the routine. Most likely the solution is to remove ALLOCATABLE as an attribute in the interface (and the actual routine).
Also, it is considered "bad form" to have a separate interface block for a Fortran routine (unless you're declaring a generic.) Better is to put the procedure in a module or make it a contained procedure. But if you're modifying an existing application, sometimes it can be useful to use interface blocks, as long as you make sure to keep them consistent with the actual routine.
b) A pointer, to an allocatable arrayThese are two different entities (object types). In the first case (allocatable), you have an object that is an array descriptor. In the second case (pointer) your have a pointer (which may be NULL) that points to an array descriptor.
Jim Dempsey
Thank you very much for your suggestion, I'm glad to tell you that this problem has been sloved!
Jim Dempsey
I am very sorry to trouble you for my new problem. I have changed my code as your advice and it runs successfully until subroutine 'new_node'. Then I found that the value of allocatable array 'ele_n' has not been passed to subroutine 'new_node' form subroutine ' zhaobian_gj01' (the value has been allocated in ' zhaobian_gj01'). The subroutines have been run successfully befor, I don't know why it comes wrong.
The code of subroutine 'new_node' is:
subroutine new_node (NP,ele_n,NE,NNE,ele_concentrate,ele_c,vcl,npt,num)
double precision t
integer i,j,k,ele_n,NP,NE,KK,NNE,NNP,m,n1,n2,n3,n4,s,npt,num,ele_concentrate(NE),ele_c(NNE)
integer ele_inital(NE,ele_n)
double precision node_xy(NP,2),vcl(2,npt)
double precision::new_point(400,2)
double precision::new_node_xy(100,2),node_xy_local_1(400,4),node_xy_local_2(400,4)
end
The main program is:
Program test_main
implicit none
interface
implicit none
implicit none
end interface
double precision,allocatable::vcl(:,:)
end
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
