29386 Discussions
Sequence of "Use" causes/masks an error
abhimodak
The snippet below will not give a compile time error. But I am thinking it should since the variable "first" is not accessible through module Two. The error is caught if Use One is written after Use Two in the program.
Abhi
Module One
Implicit None
Private
Integer :: first = 1
Public :: first
End Module One
Module Two
Use One
Implicit None
Private
Integer :: second = 2, third = 3
Public :: second
End Module Two
Program Test_Private
Use One ! This won't give an error.
Use Two, only: first, second
!Use One ! Comment the previous and Uncomment this will give an error.
Implicit None
Print *, first
Print *, second
End Program Test_Private
I agree that this seems to be a bug. I'll report it - thanks. Issue ID is DPD200139378.
