Set cursor position in a text box
davidgraham
I want to set the cursor position in a text box.
The default position appears to be at the start of the text, I want it at the end.
IanH
You can use the EM_SETSEL message to set the cursor location.  To set it to the end of the text in the control supply the length of text in the edit control (perhaps obtained using the WM_GETTEXTLENGTH message) for both wParam and lParam.
davidgraham
Thank you
