Should it work on Windows 8?
Paul_Dent
I just installed Visual studio 2022 on a windows 8 machine, followed by newly donwloaded Intel Fortran ONE API
I guess it's a trial version with some limitations because I was not asked to buy anything!
I wrote a very short test program and it compiled. But I can't find a .exe file so I can't run it.
Should I expect one?
Another issue is that there is no control over posurce file names. They are just called Source1.for, Source2.for etc automatically.
Are the above limitations of the trial instal, Windows 8 problems or what?
Paul
Paul_Dent
I found the problkem with missing urctd.lib
It seems that, if when installing VS2022 you check more than the "desktop c++" boc, then it falis to install Windoiws SK(10).
I re=installed VS2022 with ONLY "desktop C++" checked and now it works in Winoidws 8.1 fine.
mecej4
The current OneAPI compiler packages are free to install and run, subject to your accepting the license conditions. A license file is not needed, and what you installed is not a separate and limited "trial" version. Please see the FAQ. The release notes contain information on prerequisites (OS, software dependencies, hardware).
Paul_Dent
OK that is great. I found another post having the same problem and Steve Lionel had found what was wrong, I will try that
Paul_Dent
The tip given by Steve Lionel to another poster with the same issue worked for me  Apparently, it's not enough to create a new FORTRAN file by typing it into the editor. You have acutally ADD it to the project too. You didn't need to do that in CVF, it was automatic.  So befofre, it was compiling an empty source folder. It didn't complain, so I didn't know.
Having added the FORTRAN source file to the project, it now compiles, but when I try to link, I get:
error link 1104: Can't open file ucrtd.lib
There isn't such a library file on my machine.   My program is very short and not asking for anything unuusal. AM i just missing a librarry file, and if so, where can I get it?
andrew_4619
"is that there is no control over posurce file names. They are just called Source1.for, Source2.for etc automatically"
If you ask VS to create new Fortran source files  and don't specify a name these are default names. Later , you can right click the file name in solution explorer and rename them if you want also.
Paul_Dent
