- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
First, see this Dr Fortran blog: https://software.intel.com/en-us/blogs/2017/03/27/doctor-fortran-in-it-takes-all-kinds
Second, try this:
program test implicit none integer, parameter :: WP = selected_real_kind( p=15, r=307 ) ! Look into precision and range real(kind=WP) :: t real(kind=WP) :: t_next t = 120.24_wp t_next = t - 0.04_wp write(*,*) 't=',t write(*,*) 't_next=',t_next ! Look into EPSILON and comparison of floating-point values if ( abs(t_next/120.2_wp - 1.0_wp) <= epsilon(t_next) ) then write(*,*) 'It works' else write(*,*) ' It doesnot work, what is the problem?' write(*,*) ' t_next inside if logic=',t_next endif stop end
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Jeffrey, you seem to expect the computer to do exact decimal floating point arithmetic, since you think that 120.24 - 0.04 = 120.20. The reality, however, is that the base used in the processor for floating point is 2, not 10. In binary floating point, even a "simple" number such as 0.1 may not be represented exactly.
Dr. Fortran's article goes into this question in more detail.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Guys, thanks for the helps. I am an engineer and don't know too much about the computer science. Forgive me if I ask a stupid question. I used this kind of checking logic often and it works until I use the Intel Parallel Studio XE 2017 Update 2 Composer Edition for Fortran Windows. It works in my Intel 2010 version compiler. I thought that if I declare the variables as a double precision, then it should compare two numbers up to 10 digits decimals. I ran with a debugger and watched the number. Although, the t_next shows exactly 120.2000000000 but still won’t go in to the correct path. Is this to do with the new compiler?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
More reading: http://software.intel.com/en-us/forums/topic/275071#comment-1548438 (Read all three parts.)
While the debugger shows 120.2 the actual infinite precision decimal value is not exactly that.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Did you try the code in Message #2? If not, can you please try it both with your latest compiler version as well as the oldest you have i.e.,,the 2010 version?
Note you can apply your engineering background here: think of it as comparing a manufacturing product against a benchmark; you need to eliminate the random deviations in each and evaluate whether there are any systematic deviations in the product relative to the benchmark. That is effectively what the code in Message #2 does by determining a relative error from unity and comparing it with the epsilon of the number representation.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
What do you mean by "this kind of checking logic", and what is it that you wish to check?
If you watch real numbers in the debugger, you are seeing a for-human-eyes representation that is an approximation of the internal IEEE binary 64-bit representation. You can right click in the locals window in the debugger and set "hex view" to see why two numbers that agree to 10 significant decimal digits may be unequal -- equality requires that all 64-bits match.
Enter "120.42" into the online IEEE-754 emulator at http://babbage.cs.qc.cuny.edu/IEEE-754.old/Decimal.html and observe that there are no trailing zeros in the binary representation, although the mantissa in decimal notation is 1.8787500000000000.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Got it! Thanks.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
