29285 Discussions
Simulation with Adam 2013.2 and Easy5 2013
Pramod_M_
Hi Stev,
I want to do the co simulation with Adam 2013.2 and Easy5 2013. MSC support center asked me to install visual studio 2010 and then intel-visual-fortran 12.0. Can you provide me the link that I get visual-fortran 12.0 trial version for 30 days, as I am testing my first  trial. Though I register for the Intel site i got only https://registrationcenter.intel.com/en/products/ 2016 products.
Also if I could not get 12.0 compiler; may I use the 16.0 one and will it be allow me to do the Adam 2013.2 co simulations with Easy5 2013.
Looking forward your answer,
Pramod
Kevin_D_Intel
Hi Pramod - Since you already registered for the 30-day evaluation then you can obtain the older Intel® Fortran 12.0 release. Please refer to the knowledge base article How do I get an older version of an Intel® Software Development Product? for instructions on getting older versions.
I reviewed the Adams 2013.2 Installation and Operations guide and confirmed they stipulate using the Intel® Fortran 12.0 (Intel® Visual Fortran Compiler for IA-32 or Intel® 64, Version 12.0 Build 20110427). That specific version translates to the Intel® Fortran Composer XE 2011 Update 4 which is available via the Intel® Software Development Products Registration Center (IRC) so refer the earlier instructions for obtaining this release.
I cannot advise you about using a newer Intel Fortran compiler release with the Adams and Easy5 software because I do not know about their dependencies so I recommend you use the 12.0 version they stipulate for now, and not spend any of your 30-day trial time exploring using the newer 2016 release.
Good Luck. Let us know whether you have any other problems or questions.
Pramod_M_
Hi;
I am going to download Intel® Parallel Studio XE Composer Edition for Fortran Windows* { Version 2011, update 4} as you suggest . So I want to  confirmed again this is same as  “ Intel Intel Fortran 12.0 (Intel® Visual Fortran Compiler for IA-64, Version 12.0 Build 20110427) as this is suggested by Adams 2013.2 to do the co simulation with easy5 2013. . Kindly confirmed me.
Pramod
Kevin_D_Intel
Yes, I already confirmed this before my earlier reply. You have a typo where you wrote, "IA-64". That's an Itanium designation. I'm sure you meant Intel® 64. Here are some additional details to confirm. The download file you want is named, w_fcompxe_2011.4.196.exe. The contents of that package include:
Package created for w_cprof_p_12.0.4.196
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 12.0.4.196 Build 20110427
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
Intel(R) Visual Fortran Compiler XE for applications running on Intel(R) 64, Version 12.0.4.196 Build 20110427
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 12.0.4.196 Build 20110427
Intel(R) Parallel Debugger Extension 12.0 Update 4
Intel(R) Math Kernel Library 10.3 Update 4 for Windows* OS
Pramod_M_
Thanks a lot :)
Kevin_D_Intel
You're welcome!
