unclear compile error
Boyd_G_1
When I compile (build) my fortran code, which compiled and ran some time ago on an IBM mainframe, I get the error:
#5507 there are multiple unnamed main program declarations in this file
and I don't know where to start to repair.  Help?
mecej4
The source code probably got corrupted during the transfer from the mainframe. Typically, in fixed form Fortran, if the source contains tabs or if some characters got lost, you may have a source file in which, say, the second subroutine statement in the file starts before column 7. The rest of the subroutine is seen as a main program by the compiler and, if there was a main program already scanned, the compiler would give the error message that you saw.
We could be more specific if you can show the source code.
Boyd_G_1
Thank you for your help.  I reviewed the file looking for any mis placed letter in col 6 - none found.  However, it turns out that I have multiple BLOCK DATA blocks - and naming them solved error.  I'm thinking the multiple BLOCK SATA's must have been interpreted as a MAIN.
So I'm moving forward!  Thank you!
mecej4
Normally, it is at link time that multiple definitions of code symbols (subroutines, functions) and data symbols (named blocks) are detected and reported. The Intel compiler can see that there is something wrong when two blocks with the same name (or with no names) occur in the same source file. However, the messages that it gives can be confusing! The code
      program too_many_blocks
      implicit none
      integer a,b,c, p,q,r
      common /abc/a,b,c
      common /pqr/p,q,r
      write(*,*)a,b,c
      write(*,*)p,q,r
      end program
      block data bb!B_abc
      implicit none
      integer a,b,c
      common /abc/a,b,c
      data a,b,c/10,11,12/
      end
      block data bb!B_pqr
      implicit none
      integer p,q,r
      common /pqr/p,q,r
      data p,q,r/22,21,20/
      end
results in the message
blks.f(23): error #5507: There are multiple unnamed main program declarations in this file
      end
compilation aborted for blks.f (code 1)
If I name both blocks as 'bb', the message becomes
blks.f(18): error #5508: Declaration of routine 'BB' conflicts with a previous declaration
      block data bb!B_pqr
If the two block data-s are placed in separate files, at link time we see
blk2.obj : error LNK2005: __UNNAMED_DATA$ already defined in blks.obj
blks.exe : fatal error LNK1169: one or more multiply defined symbols found
It should not be too hard for the compiler to differentiate between code symbols and data symbols.
